Low Pressure In One Sprinkler Zone - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-20-2018, 05:18 PM   #1
Rewards Points: 14
Low pressure in one sprinkler zone
Hi, what could be the result of low pressure in one sprinkler line? New Home so I’m unsure if it was working properly last year, system was already blown out when i was doing the walkthrough. Thanks.
pisano772 is offline   Reply With Quote
Old 04-20-2018, 05:22 PM   #2
Guapo
Rewards Points: 11,950
Re: Low pressure in one sprinkler zone
Is that zone furthest from the house? Pressure drop can be caused by a lot of things. Look in the pit box for a leak.
Guap0_ is offline   Reply With Quote
Old 04-20-2018, 05:44 PM   #3
Rewards Points: 1,042
Originally Posted by pisano772 View Post
Hi, what could be the result of low pressure in one sprinkler line? New Home so Iím unsure if it was working properly last year, system was already blown out when i was doing the walkthrough. Thanks.
You have a 1 year warranty from the builder, notify them if the problem and get it on record, they should take care of it from there.
Canarywood1 is offline   Reply With Quote
Old 04-20-2018, 05:53 PM   #4
Rewards Points: 14
Sorry I should have worded it better. It’s not a new house. I’m new to the house. Just bought it this winter.
Old 04-20-2018, 05:55 PM   #5
Rewards Points: 14
No it’s actually the first zone. I called a sprinkler company and they instantly told me they need to dig to find a leak without even looking in the pit box.
Old 04-20-2018, 06:04 PM   #6
Guapo
I was a helper on a number of sprinkler installations. You may not have to dig as much as they say. Walk around that zone. You may see signs of the leak w/o digging.
Old 04-20-2018, 06:14 PM   #7
Rewards Points: 14
I tried to walk around to see if i saw any signs of leaking from the ground but couldn’t find any. That’s why I’m wondering if it can be a diaphragm or anything that would be an easy fix.
Old 04-20-2018, 08:26 PM   #8
Guapo
If there is a leak, the ground will be colder & softer, in that spot. Also, do some of the heads have more pressure than the others?
Old 04-20-2018, 09:31 PM   #9
Msradell's Avatar
Rewards Points: 818
Another possible cause of your problem is the partial plugging of the control valve for that zone. The valves are quite easy to disassemble and check to see if there is any plugging. Some of them even have a small strainer screen internally.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 04-21-2018, 06:15 AM   #10
Rewards Points: 7,542
Exactly. Might not be so obvious to you or me though.
Once had a landscaping company doing some work at my place, and after that one zone was bad. They tried for a while to find it, but eventually gave up and called their irrigation guy. Owner of the irrigation company walked around for about half a minute, pointed down and said "right here". Ground was soft.
Suppose it could be the valve too. Debris does manage to get in. But I think it is more common that if a pebble/rock gets into the valve, it will end up under the diaphragm an keep the valve from shutting off fully.
SPS-1 is online now   Reply With Quote
Old 04-21-2018, 07:05 AM   #11
Guapo
I think that I could find it & I think that he could find it too. It might take some time.
Old 04-21-2018, 07:14 AM   #12
When they put in my sprinkler system, I took a photocopy of the property survey, and sketched in where all the sprinkler lines ran. Has come in handy several times. They used a trencher, not a slitter, so it was pretty obvious where they had run lines.
Pressure Reducing Valve for sprinkler Drip system bluepants42 Plumbing 2 07-29-2017 09:18 PM
Sandblasting: Pressure Pot Set Up KathrynCecelia Tools 1 01-21-2016 06:19 PM
Water pressure problems maddog1 Plumbing 7 11-10-2014 05:37 PM
Added new popup sprinkler and pressure is horrible... Advice please! FLHomeOwner Landscaping & Lawn Care 7 02-18-2013 04:06 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
