Level Area For Swingset - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jwiens
Old 09-04-2015, 07:50 PM   #1
Rewards Points: 180
level area for swingset
I need to level an area for a swing set. I also want to put down some pea gravel under the bottom wood that sits on the ground (square shape) so that water drains away from the wood. In my mind I am thinking of digging a square trench say 1' wide, fill with gravel and then put the swing set base on top of the trench.
I'd love suggestions here, but the main question I have is how do I make sure I get everything level?
The attached picture is where the swing set used to be at our old house. The reason i am thinking of doing a trench rather than just putting down a ton of pea gravel and leveling is because I don't really want the rocks overflowing into our grass area.
Thanks.
jwiens is offline   Reply With Quote
Old 09-04-2015, 11:04 PM   #2
Rewards Points: 744
how to make level? spread the pea gravel, git er flat, by spreading/screeding with a 2x4. When ya think ya get 'er close, lay a level down, 'n see whatcha got!
Seattle2k is offline   Reply With Quote
Old 09-05-2015, 07:25 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... With one of these,...
Bondo is online now   Reply With Quote
Old 09-05-2015, 10:22 AM   #4
Rewards Points: 180
I just wasn't sure if I should do what I have seen done for concrete slabs where they use a line wrapped around stakes in the ground or if I could get away with a simple level.
Thanks.
blitzen likes this.
Old 09-05-2015, 02:36 PM   #5
iminaquagmire's Avatar
Rewards Points: 338
IMHO, pea gravel is a bad idea here. It doesn't compact and it gets caught in shoes etc to later then scratch floors or generally just make a mess. If your looking to level the area and allow drainage, I would dig a trench where the base of the playset sits about a foot by 6" deep and fill with paver base (limestone screenings). Compact and set then put your mulch in. The mulch will drain well enough but wont track.
iminaquagmire is offline   Reply With Quote
Does a concrete slab floor need to be level prior to tile installation? Malcolm Flooring 9 06-03-2014 09:39 PM
How 'level' is level? BOUTYM Flooring 2 09-04-2011 05:30 PM
level question countrystyle Tools 14 05-01-2011 11:35 AM
Level off a 20' x 10' area next to my house mongor Landscaping & Lawn Care 4 06-28-2010 07:34 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
