Lawn With A Patch Of Dead/??? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 04-24-2020, 12:08 AM   #1
Rewards Points: 308
Lawn with a patch of dead/???
Any recommendations on how to get this lawn healthy?
Lawn with a patch of dead/???-1.jpg   Lawn with a patch of dead/???-img_20200423_175911.jpg
ken33xx is offline   Reply With Quote
Old 04-24-2020, 04:38 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,570
Re: Lawn with a patch of dead/???
Dig up a small area of the "dead" grass, really deep to see if you have grub worms. They cause this type of dying off of grass. If so, check with your local extension service to see what they recommend locally for your problem.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 04-24-2020, 04:43 AM   #3
Rewards Points: 6,430
I've read, on the net, so it must be true, if we pull on a tuft of the dead appearing grass and it's easily pulled grub worms have probably eaten the roots.
SeniorSitizen is offline   Reply With Quote
Old 04-24-2020, 06:48 AM   #4
Rewards Points: 10,804
Start with some background.
-Where are you located ?
-When did you first notice the brown grass?
-Is this sudden and only in one spot, or throughout your lawn ?
-Do you know what type of grass you have ?
SPS-1 is offline   Reply With Quote
Old 04-24-2020, 09:32 PM   #5
DoomsDave's Avatar
Rewards Points: 13,890
Where are you?
City/County and state Province is enough
Miami and Manitoba are different.
Life is one long teaching moment.
DoomsDave is offline   Reply With Quote
Old 04-25-2020, 01:27 AM   #6
Rewards Points: 308
I'm in Az.
I went to Home Depot and it was recommended I try:
https://www.homedepot.com/p/Ironite-...9057/100598503
It was also recommendED I increase the sprinkler system to 20 minutes (4) times a week.
Old 04-25-2020, 07:41 AM   #7
Naildriver
chandler48's Avatar
Deer in the headlights.
What did you find when you pulled up the dead grass?? Pictures?
Bud9051 likes this.
Larry......
Old 04-25-2020, 08:19 AM   #8
Rewards Points: 2,820
Hi Ken: "I went to Home Depot and it was recommended I try:" That was good for a morning laugh.
I have known and had to deal with some of the sales people at the box stores and learned to not take their advice seriously. As long as you buy SOMETHING they really don't care if it works and product knowledge was not part of their job application.
Let us know what you find under that grass as suggested.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 04-26-2020, 05:18 AM   #9
Rewards Points: 26
We have a similar problem in the yard, but there are no pests. I don’t know what to do with it, the grass dies (((
Micaella is offline   Reply With Quote
Old 04-26-2020, 06:26 AM   #10
Should really start a new thread. Same questions to you as post #4, if you want intelligent answers rather than WAG's.
Old 04-26-2020, 06:39 AM   #11
Rewards Points: 26
Thank you)))
Old 04-26-2020, 04:58 PM   #12
Rewards Points: 308
Ok. first I tried pulling out some of the grass to see how loose it was. Couldn't easily pull it out.
Next I dug up some of the patched area but didn't see any grubs. I called a nursery and told it's unlikely to be grubs because the AZ weather is too hot.
In any event I adjusted the sprinkler heads and will wait a few more days to see if there has been any improvement.
