Lawn Mower Suction - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-07-2017, 10:19 AM   #1
From Philadelphia
Rewards Points: 291
Lawn Mower Suction
Curious question that you probably know the answer to. Do typical lawnmower blades spin in such a way that they lift/suck the grass up towards the blade before cutting it? I assume so, because the opposite would cause the mower to blow the grass down against the ground and not get cut, and also maybe even make the mower hover up of the ground!
Am I right in my assumptions?
hellohello is offline   Reply With Quote
Old 01-07-2017, 12:12 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Re: Lawn Mower Suction
Ayuh,.... That's correct,...
The little bent up parts of the blade causes the up-draft,...
Old 01-07-2017, 03:00 PM   #3
Rewards Points: 4,170
Mulching blades are designed with even greater lift like this.
stick\shift is offline   Reply With Quote
Push lawn sweeper vs Lawn Mower rjordan392 Tractors & Mowers 2 11-25-2014 08:55 AM
Lawn Mower Question - Push or Riding? cbarr81 Tractors & Mowers 15 10-19-2012 09:44 AM
broken lawn mower, now what? jason41987 Landscaping & Lawn Care 12 06-04-2012 05:15 PM
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 09:29 AM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
