Lawn Irrigation - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-31-2015, 04:28 PM   #1
Rewards Points: 151
Lawn Irrigation
I'm looking at putting in an expensive sprinkler system, the RainBird 32ETI. Each system has two lines with 3 pop-up heads per line. Based on the size of my yard and coverage, i'm looking at 3 systems with different timer settings for each so that no two systems are running at the same time. Two systems off the back faucet from a "Y", and one off the front.
Questions:
To run these all off a single timer, I would need to run new lines, one to each system, with each line coming back to a central timer, or is there another option?
thanks,
mahjohn is offline   Reply With Quote
Old 05-31-2015, 06:16 PM   #2
Rewards Points: 188
Have you considered a traditional irrigation system that uses a single timer vs three kits?
Dan
djlandkpl is offline   Reply With Quote
Old 06-01-2015, 07:44 AM   #3
Rewards Points: 151
limited knowledge of sprinkler systems on my part....i know the RainBird 32ETI is $170, so for the sprinklers, minus renting a trencher, i could have something for ~$600. How this compares to a standard system with one controller, haven't looked at that yet, however, it seems that the controller piece is the most expensive of the configuration. I'll also have to check the cost of the individual components, tubing, pup-up heads, timer and see how stack up......
If you have any good starter places for me to go check-out, i'd appreciate the info. Literally "RainBird" is the only brand i've heard of....but then i see others in Google search, but have no knowledge of their reputation, quality, etc..
thanks
Old 06-01-2015, 08:42 AM   #4
Rewards Points: 188
Rainbird and Hunter are the two most common brands. I prefer the Rainbird heads as they are easier to adjust IMO. I get my supplies through sprinklerwarehouse.com. You'll want to get the poly tubing locally to save on shipping.
Depending upon the number of zones, a controller will run less than $100. You can also use 1 inch tubing so you can run more heads per zone. A single pop up rotor is around $7.00.
You'll need some additional parts like cinch (crimp) clamps, funny pipe to connect the heads to the lines, crimp tool and some adapters. To tie into your house plumbing you will need a backflow preventer which is around $100.
It sounds like a lot but it's essentially the same stuff that you get in the kit. Building your own system gives you more flexibility in sizing and you'll have the tools needed for future repairs.
Dan
Old 06-01-2015, 09:48 AM   #5
Rewards Points: 151
Sprinklerwarehouse.com, i see they have a "Sprinkler School" (which i need). Thanks!
Also....have you used, or know of anyone that has used the RainBird Design Service?...is it good, or overkill?
Old 06-01-2015, 10:12 AM   #6
Rewards Points: 188
I have not used the design service but if it is free it can't hurt.
Dan
Old 06-01-2015, 11:08 PM   #7
Rewards Points: 344
Can you clarify when you say "each system has two lines"? Do you mean zone? Are you talking about rotor heads or traditional fixed spray heads?
drew53813 is offline   Reply With Quote
Old 06-01-2015, 11:16 PM   #8
Rewards Points: 344
Mahjohn- Sorry for responding before reading a little on this system. I see that this is a kit type install. I would recommend going with a basic custom irrigation system. I am more then happy to spend the necessary time going over the basics of lawn irrigation with you. I have quite a few years of custom installed irrigation systems. I think you can get more bang for your buck with a custom system.
New lawn 3.5 acres, no irrigation 6fthook Landscaping & Lawn Care 17 04-29-2015 11:59 PM
Lawn Irrigation Question kennykenny Landscaping & Lawn Care 0 08-10-2014 03:32 PM
plastic check valve on well for lawn irrigation system jeff johnson Plumbing 0 10-05-2012 01:10 PM
Well pressure boost for lawn irrigation system. wernerp Plumbing 8 08-22-2011 10:33 PM
Need tips on winterizing lawn irrigation system...size of compressor etc. Hossenfeffer Landscaping & Lawn Care 8 12-02-2010 12:14 PM
