Landscaping Yard But What To Do With Neighbour? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-13-2015, 11:05 AM   #1
Rewards Points: 164
Landscaping yard but what to do with neighbour?
I am landscaping my yard properly with a hired professional. When he looked at my yard he mentioned that my neighbours house and land is set a bit higher than mine.
What I need to install is something that will take the water that will meet between our 2 properties and channel it to the front sidewalk which is 50 feet away. It is about 60 feet to the back alley and we have a 6' fence between us.
Is there something I can install that will take the water away between our 2 properties...our houses are about 10 feet away from each other.
hellothere123 is offline   Reply With Quote
Old 05-13-2015, 11:11 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If his is so much higher that you expect large amounts of water you can either contour the land to create a swale which will temporarily hold the water until it soaks in or if too much for that you can use the swale as a pathway to divert the water to someplace else or if neither idea sounds great you can install a French drain and pipe the water wherever you want.
Old 05-13-2015, 11:15 AM   #3
Rewards Points: 144
I would go with a French drain.I would have thought the landscaper would have some ideas.
mako1 is offline   Reply With Quote
Old 05-13-2015, 11:15 AM   #4
Rewards Points: 164
I forgot to mention that we both dont have weeping tile around our houses, and both have flooded in the past...
Old 05-13-2015, 03:55 PM   #5
JUSTA MEMBER
Rewards Points: 4,024
I vote FRENCH DRAIN.
If your landscaper did not think of this , what kind of professional are they?
ED
de-nagorg is offline   Reply With Quote
Old 05-13-2015, 04:29 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... Water flows downhill,...
Put a continuously droppin' swale along the fence line to the lower end, or ends of the lots,....
First Home First Yard First Spring cjlmparker Landscaping & Lawn Care 0 03-16-2013 02:19 PM
Suggestions on Front yard landscaping KeithWhisman Landscaping & Lawn Care 4 05-20-2011 10:14 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Help for my Front yard for landscaping cprao Landscaping & Lawn Care 25 12-22-2009 09:13 AM
