Juniper Bushes Dead At Bottom - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-11-2015, 05:42 PM   #1
Lord of Slums
Rewards Points: 1,974
Juniper bushes dead at bottom
I have some juniper bushes I planted maybe ten years ago. They looked very nice for the past 8 years. The wind has been really rough here past two years. Last two winters have been much colder than normal.
These bushes, which are 12 feet tall and maybe 18 inches wide, are dead and dieing at the bottom 4 feet. Should I tear them out, or is there some sort of remedy? I probably waited to long and will sadly have to remove them. Thanks
mj12 is offline   Reply With Quote
Old 04-11-2015, 06:46 PM   #2
Retired Moderator
Rewards Points: 7,174
You will be removing those,I bet.--To the best of my knowledge,the lower branches that died will not regrow when pruned back---
Old 04-11-2015, 07:02 PM   #3
paper hanger and painter
chrisn's Avatar
what Mike said^^
The Following User Says Thank You to chrisn For This Useful Post:
oh'mike (04-12-2015)
Old 04-11-2015, 10:04 PM   #4
TruproServices.com
TruproServices's Avatar
Rewards Points: 80
In my experience with Juniper, issues are either weather, water, disease or spider mites. I did some research and feel like there's not much chance of the limbs growing back. I think before I give up, I'd consult your local extension agent and get their opinion.
TruproServices is offline   Reply With Quote
Old 04-12-2015, 07:39 AM   #5
Retired Moderator
An interesting Juniper experience----
My father had Hawthorn Crab apple trees---and Junipers----the Junipers wer plagued by a yellow fungus---turns out the crabs were infecting the junipers---
So ,junipers were remove--new ones were planted well away from the crabs---no more trouble.
Old 04-12-2015, 08:49 AM   #6
TruproServices.com
Rewards Points: 80
This is actually well documented, but you may not have noticed the trees were likely infected also with Cedar Apple Rust. The recommended treatment... Don't plant junipers near Crab Apples...I'm not making this up.
The Following User Says Thank You to TruproServices For This Useful Post:
Bottom Plate for Stud Wall svaic00 Building & Construction 3 07-10-2012 03:07 PM
Patio door bottom sill over brick/concrete block cjf1980 Building & Construction 18 04-12-2012 10:56 AM
How to repair my roof truss - cut bottom chord darlingm Roofing/Siding 10 01-05-2012 08:48 AM
Outlet is dead but ears are hot!? Whassup? Hubandwif Electrical 33 03-23-2009 09:01 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
