Irrigation Schedule For Overseeding? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-27-2015, 01:59 PM   #1
Rewards Points: 648
Irrigation Schedule for Overseeding?
I just oversewed my lawn. I know that it's important to keep the seeds moist during the germination phase. How should I set my irrigation system for overseeding?
In other words, how many times per day and how long each time?
kcrossley2 is offline   Reply With Quote
Old 09-27-2015, 07:12 PM   #2
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 862
Just keep the soil surface moist (not wet, moist). Stick your finger in once and a while and if it starts to feel dry give it some water. You just need to keep the surface moist, so it won't take a lot. The established grass will help hold water so you shouldn't need to do it as often as when putting down seed for new grass.
Thunder Chicken is offline   Reply With Quote
Old 10-06-2015, 05:54 PM   #3
Rewards Points: 68
2-3 times per day for about 10 minutes to just keep the soil slightly wet (will also depend on full sun vs. shade). you basically want your sprinklers to come back on as soon as it's dried out. You don't want to water deep at all at this point, so 10-15 minutes is enough.
pats12 is offline   Reply With Quote
Please help on my irrigation issue!!! anthony232 Landscaping & Lawn Care 2 10-05-2015 03:44 PM
strange noise under house when irrigation system shuts off eitnum General DIY Discussions 7 08-16-2014 02:26 PM
Small Schedule PVC Pipe & Fittings Zekester Plumbing 2 07-26-2012 10:39 PM
Pressure Reducing valve and location irrigation branch line ironqqq Plumbing 3 07-14-2012 01:53 PM
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 04:08 PM
