Irrigation Pipe Exposed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-11-2017, 05:10 PM   #1
Rewards Points: 45
I have a pvc pipe 5/8" in diameter that is only 2" below grade going over a small garden trench that is a total of 5" below grade.
My question is how can I protect that pipe from not being broken by someone walking on it? I am open to filling up the trench but not sure how to reinforce it from the top and bottom.
Does anyone have any ideas?
Thanks,
Randal
sharingsunshine is offline   Reply With Quote
Old 05-11-2017, 05:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Re: Irrigation Pipe Exposed
Ayuh,.... Compacted native soil, below, 'n above,....
Bondo is online now   Reply With Quote
Old 05-11-2017, 05:42 PM   #3
Rewards Points: 300
bag of sac crete?
KPDMinc is offline   Reply With Quote
Old 05-11-2017, 08:06 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,156
Not the greatest set-up, but I'm not exactly sure how a pvc pipe covered in 2" of soil could be broken by being walked on. You could dig the pipe down to the 5" level of the other trench.
lenaitch is offline   Reply With Quote
Old 05-15-2017, 04:15 PM   #5
Rewards Points: 45
Thanks for all of your suggestions. However, I am not clear how to compact soil without a compactor is there a way to do that manually since I don't have access to a machine for that purpose?
Old 05-15-2017, 04:55 PM   #6
Rewards Points: 300
use slurry or sand, or water down your dirt as you backfill
Old 05-15-2017, 05:00 PM   #7
Rewards Points: 45
Thanks, that makes a lot of sense. I will definitely add some water.
Old 05-15-2017, 05:55 PM   #8
Bondo's Avatar
Ayuh,.... For the size of the fill we're talkin' 'bout,...
Hands, 'n feet will most probably do,....
Old 05-15-2017, 05:58 PM   #9
Rewards Points: 1,042
Or the end of a 2x4
Canarywood1 is offline   Reply With Quote
Tags
gardening , irrigation , pvc pipe
Bad FlowGuard Gold pipe CraigHutton Plumbing 7 06-12-2017 05:36 PM
Best pipe to use without sag for projection screen scampy74 Home Theater 4 08-30-2016 10:27 AM
Sewer Back Up/ Pipe Relining Question newbinca Plumbing 9 05-10-2013 12:23 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 08:00 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
