Irrigation Flex Piping Slow Leaks - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-24-2018, 04:43 PM   #1
Rewards Points: 320
Irrigation Flex Piping slow leaks
The above is the type of piping I'm referring to. An issue I have had for a while now is that I get a small amount of leakage from where the barb goes in around the hole.
I realized this after using the hole punch way too long when it got dull. Instead of making a clean cut hole, the hole ended up being slightly jagged. I should have thrown it away and purchased a new sharper punch tool in hindsight.
Rather than replacing all of the flex piping, I'm wondering if there is a way to fix the slow leaks using some type of adhesive on the hole and barb. I have been removing many of the barbs and putting plugs in as I took out many plants so plugging up the hole is not an issue since no water coming out is needed.
Does anyone know of a way other than a coupler or new water line that will stop the leaks?
monkeyfarmer is offline   Reply With Quote
Old 05-24-2018, 06:59 PM   #2
Rewards Points: 1,042
Re: Irrigation Flex Piping slow leaks
Plug the ones that are leaking and replace with a new barb, that is after you buy a new hole punch.
Canarywood1 is offline   Reply With Quote
Old 05-25-2018, 09:06 AM   #3
Rewards Points: 576
I see that there is a small indent in your tubing. A trick is...after you have inserted your drip fitting....pull it out gently to form a tighter seal. The indent will have gone away.
Goof plugs have two barbs....use the bigger one.
If all else fails.....plant mint underneath.
Cedrus is offline   Reply With Quote
Old 05-28-2018, 05:45 PM   #4
Rewards Points: 320
Thanks! You know I had no idea the goof plug big end was for plugging. I just thought it was to hold on to. I'll have to try the pull back trick also, similar to when hooking up water lines to quick fittings in reverse osmosis I suppose, have to pull back a little after.
Xypex or other sealant for foundation leaks MidgeTenant Concrete, Stone & Masonry 3 06-20-2016 06:58 AM
Testing new piping for leaks digitalplumber Plumbing 15 05-14-2015 10:49 AM
Weird siding leaks skov Roofing/Siding 7 04-12-2015 04:23 AM
sediment trap with gas flex line? diggerdave Plumbing 10 02-11-2009 06:14 PM
Pinhole Leaks in Copper Piping 27narrow Plumbing 17 12-28-2007 06:38 PM
