DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Landscaping & Lawn Care (https://www.diychatroom.com/f16/)
-   -   installing poly pipe for sprinkler (https://www.diychatroom.com/f16/installing-poly-pipe-sprinkler-55993/)
newgarage 10-26-2009 03:02 PM
I am having a asphalt driveway installed soon in NY and will add an inground lawn sprinkler system in the future. Before the paving is done I was planning on putting a length of poly pipe in the ground to cross the 17' width driveway area to a small section of the lawn on the other side of the driveway. Is this a good idea or will weight on the driveway collapse the pipe? Should it be a certain depth?
user1007 10-26-2009 04:08 PM
It is a great idea. Leave yourself enough room for 3/4"-1" pipe and wire for a remote valve or low voltage lighting if that is part of plans. You could use schedule 80 if you are really worried about crushing it and since you need just 20' or but schedule 40 will be sufficient. Dry fit caps on to the ends to keep it clear. I would be more worried about burrying it below your freeze depth than how far under the slab to put it. You will not be putting enough force directly on it to crush it.
teamo 10-26-2009 04:12 PM
I would run a pvc pipe across the driveway. You can use fittings to connect the poly pipe to the pvc or you can use an oversized pipe and use it as a sleeve. 18-24" should be good for depth. If there is anything that has to go over there in the future (electrical, water, etc.) now is the time to run it.
downunder 10-27-2009 05:22 PM
I would even spend the extra $4.85 for an extra run of pvc and cap it off just in case for some future project.:thumbup:
Reddhead 07-24-2010 10:38 AM
Old post, I know. If it were me I'd run a 4" peice of PVC for all kinds of future stuff. Wishing I'd thought of it when I had my house built.
Oh well.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
