Installing A Fence Post On A Multiple Slope - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-16-2015, 06:34 PM   #1
Rewards Points: 4
Installing a Fence Post on a multiple slope
I'm trying to replace some fence in a sloped yard. One of the posts needs to go in at a point where the yard is sloping both downhill in the direction of the fence run and downhill into the neighbors yard. Need help securing it. I tried to build the base up with dirt and put it in with concrete but it's already moving around. I've included some pics to help explain.
Installing a Fence Post on a multiple slope-phone-dump-feb-15-008.jpg   Installing a Fence Post on a multiple slope-phone-dump-feb-15-009.jpg   Installing a Fence Post on a multiple slope-phone-dump-feb-15-010.jpg
rick_E is offline   Reply With Quote
Old 02-17-2015, 11:07 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... How deep is the post,..?? the concrete,..??
More bracin' 'tween the posts will help stabilize the whole fence,...
Old 02-19-2015, 05:47 PM   #3
Rewards Points: 4
It's about 20 inches deep on the highest side with concrete all around. It still moves around in the ground though. That dirt in that slope is soft. The same arrangement worked all up and down the rest of the yard but not there.
You think adding a middle brace on either side would help? The movement is more side to side. The other thought I had was dig it away, add a vee-shaped temp wall of 2x4s and backfill it with more concrete, then remound the dirt against the new bigger plug.
Still working out the angle on the other side up where it will meet the corner post too. It's a compound angle that I've never attempted before.
Old 02-19-2015, 08:10 PM   #4
Rewards Points: 996
It's about 20 inches deep on the highest side .
thats your problem right there. go 3'+ and at least 8" round. do not backfill = dig the hole, set post add concrete.
Fix'n it is offline   Reply With Quote
Replace chain link fence post Homerepairguy General DIY Discussions 33 02-13-2015 02:09 PM
wood fence post farrington135 Building & Construction 11 05-17-2011 02:32 PM
How to replace a loose fence post preciouschristy Building & Construction 2 05-14-2011 05:06 PM
Fence Post Installation Question Jawbreaker Landscaping & Lawn Care 6 04-08-2010 10:46 AM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 01:09 PM
