DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Landscaping & Lawn Care (https://www.diychatroom.com/f16/)
-   -   Installation of Automatic Sprinklers (https://www.diychatroom.com/f16/installation-automatic-sprinklers-110360/)
roafamily 07-11-2011 09:24 AM
good morning all, i hope this is the right place to ask the question. i would like to install automatic sprinklers at my house. do you know of any links or some advice on how to do this?
thanks
paul
sippinjoes 07-11-2011 10:11 AM
http://www.rainbird.com/homeowner/de...esignstart.htm
I had a friend use the service linked to above, however he had to adjust a few things as they didn't design the overlap properly
teamo 07-11-2011 03:14 PM
I would do lots of reading and research online before doing anything. Once you come up with a plan it is not that difficult although it is hard work digging and putting everything in the ground. How much area are you doing? The first thing you have to do is take a pressure and gallons per minute (gpm) reading of your water service to see how many heads you can run on each zone. Buy a pressure gauge and do a test from one of your outside spigots to get a psi reading, then you can figure out the gpm's doing a simple test with a 5 gallon bucket and a stop watch.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
