Inground Rez To Collect Roof And Sump Water - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By lenaitch
  • 1 Post By Msradell
Old 05-03-2017, 10:41 PM   #1
Rewards Points: 132
Inground Rez to collect Roof and Sump Water
I'm about finished our Reno and moving onto backyard, part of which includes taking the roof and sump water 80' back through 4" ABS. It will be just below ground and drain to daylight.
What I'd like to do is capture a large amount of that water in a Rez which I can pump from for our lawn and garden.
How can I create a 500-1000 gallon Rez? Plastic container? Form concrete?
I assume the water would be safe for vegetable garden.
Vanner is offline   Reply With Quote
Old 05-04-2017, 10:14 PM   #2
Msradell's Avatar
Rewards Points: 818
Re: Inground Rez to collect Roof and Sump Water
Your idea certainly very doable but 1 of the questions you need to answer 1st is what is the water table in your area? If you've a high water table you don't want to use a lightweight plastic tank because the water may force it upward when it's empty. In that case you would want to use a concrete tank such as a septic tank.
If the water table is the question there are many sources of plastic tanks that are quite reasonably priced. Your best bet would be to look for one in your area because shipping can get expensive for them. You definitely want a round 1 because they are much less likely to deform under the pressure of the dirt above them.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 05-04-2017, 10:21 PM   #3
Rewards Points: 132
We're on the top of a ravine so ground water isn't an issue but I would like to keep the top at grade with a cover so I can easily access.
Drain from house would empty into top and I would need an overflow to continue the rest of the way back for big rain falls.
Maybe digging the hole and forming for concrete is the best route. Shouldn't have to worry about pressure on walls this way.
Any idea on who to source plastic Rez from?
Old 05-05-2017, 04:41 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,156
For a tank that size you might as well buy a septic tank. Just because you are on top of a ravine does not, in itself, negate ground water - I have seen free-flowing artesian springs on the top of hills. If your area is prone to freezing you might want to bury it deeper. Even if you drain it, any frost may jack it.
Bondo likes this.
lenaitch is offline   Reply With Quote
Old 05-05-2017, 09:33 PM   #5
Msradell's Avatar
Rewards Points: 818
Try this website: http://www.plastic-mart.com/category...-storage-tanks
Vanner likes this.
Old 05-06-2017, 04:47 PM   #6
Rewards Points: 132
Underground water cistern was the search I should have been doing. Lot's of 500 gallon options.
Now I have to figure out if water from roof and sump are good for growing vegetables.
Old 05-06-2017, 06:11 PM   #7
Usually Confused
lenaitch's Avatar
Can't see why not. They're what feed the plants when it rains. Unless you have contaminated soil around your foundation.
Old 05-06-2017, 10:35 PM   #8
Rewards Points: 132
Makes sense.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Basement Sump Pump for Roof Water housefixr Plumbing 4 08-26-2012 09:39 PM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Rain water collection system ChrisDIY Landscaping & Lawn Care 7 08-17-2010 03:35 PM
Re-directing Water Jak Ray Landscaping & Lawn Care 7 09-19-2009 08:53 PM
