Ideas For Removing Frankenbush - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-07-2014, 05:57 PM   #1
Rewards Points: 12
Ideas for removing frankenbush
I have idea what this plant it is taking over my neighbors fence and need ideas on removing it.
Its composed of about 1000+ small chutes as seen here
Complicating matters is it is on top of a 4 foot retaing wall.
jake83 is offline   Reply With Quote
Old 12-07-2014, 06:35 PM   #2
r0ckstarr's Avatar
Rewards Points: 82
If you can't pull it out due to the wall or fence, chop it down and kill it.
r0ckstarr is offline   Reply With Quote
Old 12-08-2014, 09:38 AM   #3
Rewards Points: 12
Yes i want to remove it complety, maybe a tool suggestion is what im after, beem hacking it with a machete to poor results
Old 12-08-2014, 10:13 AM   #4
JUSTA MEMBER
Rewards Points: 4,106
Use a Cherry picker, Small crane, overhead winch, or a similar lifting device.
Tie a ratchet strap around the entire thing, ratchet it tight tighter, Then pull it from above.
I used to work for a landscaping crew in the 60s that used this method to great success.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
r0ckstarr (12-08-2014)
Old 01-26-2015, 10:32 AM   #5
Rewards Points: 28
I had a frankenbush, final remedy. Use the ratchet strap remedy to gather all branches. Saws all, chainsaw ect as close to the ground as possible. Use one of those root/ stump removal products.drill auger down into main roots and apply the product Then if it's in the sun, cover the effected area with black plastic to cook ole franky. Go getem
Thebarn134 is offline   Reply With Quote
Old 01-26-2015, 10:38 AM   #6
Rewards Points: 28
Revisit frankenbush
Another idea, prune using elec shears. Find out what it is and when to prune and the following season it should be covered with blooms, to tell ya the truth I wish I had 300' of that hedge. See pic.
The Following User Says Thank You to Thebarn134 For This Useful Post:
oh'mike (01-26-2015)
Old 02-18-2015, 12:57 PM   #7
Rewards Points: 8
The black and decker cordless hedge trimmer has worked great for me in the past. You can also try getting a good set of garden shears too.
ftrain is offline   Reply With Quote
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 09:10 PM
Garage organizing ideas gulffl Carpentry 2 10-24-2011 01:31 PM
Need help with ideas Stuffy24 General DIY Discussions 8 08-31-2011 11:20 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 07:06 PM
Dining room renovation - looking for ideas hyunelan2 Interior Decorating 1 10-10-2009 06:03 AM
