How Should I Flatten Backyard Lawn? - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 08-02-2016, 09:47 PM   #16
Rewards Points: 3,223
Re: How should I flatten backyard lawn?
I have a similar problem with my yard. I did some research. There is a tractor attachment called a "box blade" that is designed to do exactly what you are trying to accomplish. I haven't tried it, but it seems like just the thing.
http://incomingbytes.com/landscaping...vel-your-yard/
A tiller, in my experience, will make everything loose and then it will settle unevenly and just be all lumpy again.
lenaitch likes this.
mathmonger is offline   Reply With Quote
Old 08-02-2016, 10:14 PM   #17
Rewards Points: 1,528
Would filling in the low spots instead of taking out the high spots be possible? I can't see the bad spots in the pictures very well to tell how bad it really is
ryansdiydad is offline   Reply With Quote
Old 08-03-2016, 11:49 AM   #18
Rewards Points: 1,042
Would a Harley rake help in your situation, here's a link.
Canarywood1 is offline   Reply With Quote
Old 08-03-2016, 12:04 PM   #19
Rewards Points: 312
Filling in low spots isn't an option as that would affect the grading closer to the house where the low section is. I snapped a couple pictures from right in front of the deck facing the back lot. It's hard to see the grading but you can get an idea how it slopes from the pictures since I tried the hold the camera level.
Pictures are left to right, top to bottom.
How should I flatten backyard lawn?-yard1.jpg   How should I flatten backyard lawn?-yard2.jpg   How should I flatten backyard lawn?-yard3.jpg
NewHomeDIYGuy is offline   Reply With Quote
Old 08-03-2016, 12:10 PM   #20
Rewards Points: 312
Regarding equipment.. I don't doubt there are better options besides a skid steer but I'm skeptical that many tool rental places would have them available. I can certainly ask. I also don't have a tractor so tow behind options aren't a good option for me.
Ultimately I'll either rent the skid loader or just hire someone to do the flattening part for me (shouldn't be much more than ~$1k I'd imagine). At this point I'm leaning towards hiring someone to do the flattening with a skid loader as it's the more difficult job. I guess I'd need to rent a sod cutter or buy new sod to lay down afterwards. That's certainly DIYable just involves a lot of manual labor.
Old 08-03-2016, 03:40 PM   #21
Usually Confused
lenaitch's Avatar
Rewards Points: 2,254
I guess it depends on your local availability but up here most rent-alls and even box stores rent tractors as well as skid steers. The rental availability of attachments and implements depends on local demand. I live in farm country so renting this type of stuff either from a rent-all or a willing farmer with some time is relatively easy.
You might as well resign yourself to re-sodding or re-seeding. Unless your lawn is golf-course quality it won't come up well and a skid steer or tractor will chew it up.
lenaitch is offline   Reply With Quote
Old 08-03-2016, 11:30 PM   #22
Rewards Points: 191
i have an identical problem. from what ive seen, using a tiller and a york rake along with a lawn roller seem to work. thoughts on this
rygar is offline   Reply With Quote
Old 08-04-2016, 06:31 AM   #23
ZTMAN's Avatar
Rewards Points: 638
That's a nice looking back yard. Before you go changing the grade, take into consideration the roots of the large trees. If you are lowering the grade in that area, it may expose the roots, which is more of a problem than what you think you have now.
I would think, with what you want to do, it would be about a $7k dollar job.
ZTMAN is offline   Reply With Quote
Old 08-04-2016, 11:12 AM   #24
I had my front, side, and back yard graded and seeded/blanketed for $3k... might depend on where you are..
my biggest hassle in work like this is often disposal of the sod/clay/crappy dirt that i dig up... there always ends up being more of it than I anticipated...
Old 08-04-2016, 12:02 PM   #25
Rewards Points: 312
I'd say it all depends on the size of the area. The area I'm thinking about regarding is probably a good ~1k sq ft. I imagine that would be pretty brutal to do with a tiller. If you have a tractor with some attachments it's probably def doable.
Old 08-04-2016, 12:06 PM   #26
Rewards Points: 312
Thx, and ya I've definitely thought about the roots. Fortunately I'm not looking to cut into the grade too close to the old trees, but I was planning on renting a stump grinder as needed and grinding down some remaining roots that the tree removal guys didn't all get when they removed the trees. Stump removal isn't too hard. I can rent one for $150/day or less I believe, and they aren't too hard to operate. They were some very large oaks trees removed so I'm sure I'll run into some roots. Thx for the heads up.
Ya, $7k is too darn much for what I'm willing to pay. I'm still talking to some friends to see what they say regarding the skid steer. Maybe I can get someone to come over and operate the skid steer and pay them a decent sum to do the grading. Worst case I'll just delay the project a couple years till I have more time to tackle it. Good thing is it's no rush.
Old 08-04-2016, 01:23 PM   #27
47_47's Avatar
Rewards Points: 320
Originally Posted by NewHomeDIYGuy View Post
I'm doing this purely for cosmetic/my personal preference to have a nice flat area to play on for myself and the kids.
That's exactly how my backyard started out.
Still need to level the yard now it's for the grandkids.
de-nagorg likes this.
47_47 is offline   Reply With Quote
Old 08-04-2016, 02:08 PM   #28
Rewards Points: 312
Ha, no grandkids. We got a 9 month old and almost 2.5yr old so my time to escape from watching them and play/flatten the yard is limited. If I could get a couple weekends to not deal with the kids I think I could get it done, but no such luck.. :p
Old 08-04-2016, 02:37 PM   #29
47_47's Avatar
Rewards Points: 320
That's what I thought too. They grow up so darn fast. Good luck and have fun with them.
Old 08-09-2016, 09:50 AM   #30
Rewards Points: 297
If you rent a skid steer, particularly a wheeled machine with a bucket, and try to do this on your own . . . you are going to make a very big muddy mess of what is currently a pretty good looking lawn. Wheeled bobcats are pretty brutal on lawns when they make turns. Buckets are great for moving loose material, but it takes a fair amount of skill to use one to cut down hills and make a nice looking surface.
My advice would be to not let the "badass" factor of renting a bobcat and having a go at it on your own lure you in. It sounds way cooler in your head than it will be about 30 minutes in. Things looks pretty good right now. A first timer in 3,000 lb machine could leave things looking way worse than they started.
Bobcats in general are not well suited to fine grading work, since they are so short. They just sort of follow the contours of the land that is already there. A longer piece of equipment is better able to cut/fill spots that are out of plane. With something like a harley rake or box blade attachment, a bobcat essentially doubles in length.
red92s is offline   Reply With Quote
restoring lawn in backyard in texas with big tree bman1968 Landscaping & Lawn Care 4 07-20-2016 08:18 AM
Standing water in my backyard!! sam2015 Landscaping & Lawn Care 2 04-30-2015 12:17 AM
3 Outdoor Tips to Spruce up Your Backyard Rooym Landscaping & Lawn Care 2 01-22-2015 07:01 PM
Need help with front lawn greentrees Landscaping & Lawn Care 8 10-28-2014 09:35 PM
help me please o4u2adore Landscaping & Lawn Care 3 03-16-2010 08:09 PM
