How To Setup Curved Paver Walkway? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-04-2018, 08:56 PM   #1
Rewards Points: 330
How to setup curved paver walkway?
What type of form boards should I use to screed the sand? I would need something that is flexible. Also, how would the pattern work? Do I just slightly move each paver to have more gaps, or do I just go straight and cut the ends? I hope that made sense.
weatheredwood is online now   Reply With Quote
Old 03-04-2018, 09:54 PM   #2
JUSTA MEMBER
Rewards Points: 3,990
Re: How to setup curved paver walkway?
There are flex-form boards sold at the box stores.
Usually 1X4 inch by 10- 12 feet long, and 1/4 inch thick.
You use 1/2 inch rebar as pegs to form your curve and flex the board around the curve, tying it to the re-bar driven into the ground.
As for your pattern , that is worked out trial and error style, before deciding on how you want it to look.
And Yes there will be cuts to be made, it all depends on how your layout is.
Without a picture I am at a loss to give specifics.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
weatheredwood (03-05-2018)
cement edge around paver walkway nilanjan General DIY Discussions 2 04-23-2016 10:24 AM
Help with paver walkway base material maddog1 Landscaping & Lawn Care 3 08-12-2014 08:43 PM
Building Paver Walkway / Rain jimleigh1313 Landscaping & Lawn Care 0 10-05-2012 10:19 AM
Edge restraint on new paver walkway Andy54 Concrete, Stone & Masonry 7 08-03-2012 02:31 PM
Need advice on where to put the paver walkway in the backyard htabbas Landscaping & Lawn Care 11 10-29-2011 11:34 PM
