How Much Product To Put Down With 30 Gallon Tow Behind Boom Sprayer - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-28-2017, 10:17 AM   #1
Rewards Points: 2
How much product to put down with 30 gallon tow behind boom sprayer
Hello!
I am trying to tackle my lawn in the N. Dallas area. I have a good base with Bermuda grass. I have a 30 Gallon tow behind sprayer with 3 spray nozzles.
Specs: 3MPH, @20PSI, .21 Gall per 1000 Sq Ft. (9.10 Gal per acre), 38,000 Sq Ft area to spray.
I am using prodiamine with 2,4,-D tank mix, Non-ionic Surfactant, blue lawn dye.
Here is what I thought was correct:
Prodiamine .4 oz x 38 (38,000 sq ft) = 15.2 Oz.
2,4-D = 6 1/2 tsp per 1000 Sq ft. = 37 oz?
Surfactant = 8 Oz.
Blue Dye = 6 Oz.
Mixing all of this with 8 Gallons Water.
Does this sound right?
Any other suggestions on chemicals to use?
Thanks, Justin.
justin.foust is offline   Reply With Quote
Old 02-28-2017, 10:07 PM   #2
Rewards Points: 1,002
Re: How much product to put down with 30 gallon tow behind boom sprayer
I use a product called Amine 400 which has the 2-4-D. I read the destructions and came up with 1 oz./ gallon of water.
I rescued a shady lawn a few years back which was overgrown with creeping charlie. It is fairly clean now. I looked it over with some other guys and it was a toss up as far as killing everything or starting over, that's how bad it was.
cleveman is offline   Reply With Quote
Old 02-28-2017, 10:29 PM   #3
Msradell's Avatar
Rewards Points: 818
Don't forget that all your calculations are based on a volume per thousand square feet. You need to figure out what speed you need to be going with that tagalong sprayer to get that application rate. Getting the mix correct is just the starting point and actually quite easy to do. The hard part is applying it at the correct rate per thousand square feet.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 02-28-2017, 11:10 PM   #4
RRH
Rewards Points: 1,332
First off you really need a gallon of water per 1000 sqft. You have to be able to wet the leaf blade of the weed for good results.
Least I would even consider is half a gallon.
20 psi seems weak but could still work.
But you are going to have to do a calibration test or you are just guessing.
Mark off a 1000 sq ft area. Use plain water for test. Run the sprayer at and tractor at a set speed. See how much water you use.
Need to rig up some jars or whatever under each sprayer head to catch the water ( duct tape, wire etc...) to measure.
You have to figure out how much water the sprayer is putting out at what speed . Before you can figure of the weed control.
Little bit of a pain but you only have to do it once.
Take a shortcut and you are not going to get it right. Either way to much or to little.
You will figure out if you have to go very slow for that sprayer or go over the lawn twice for it to work.
RRH is offline   Reply With Quote
sink sprayer gushing but hose stuck! carolitis Plumbing 1 06-08-2016 07:29 PM
using Lowes edge precision flooring Andy McDonald Flooring 68 03-17-2012 01:42 PM
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 12:51 PM
Help me choose the right sprayer bokeh Painting 19 05-26-2011 05:56 PM
kitchen sprayer troubleshooting jhustwit Plumbing 6 06-14-2010 01:46 AM
