How Many People Should I Hire To Lay Sod? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 2 Post By jlhaslip
  • 2 Post By SPS-1
  • 2 Post By chandler48
Old 08-07-2017, 05:08 PM   #1
Rewards Points: 332
How many people should I hire to lay sod?
It's 7 pallets that are 400 sqft each. I would like to get it laid down pretty quick. Would two people off of craigslist be enough? I guess it should be laid down within 4 hours.
weatheredwood is offline   Reply With Quote
Old 08-07-2017, 06:12 PM   #2
Rewards Points: 7,540
Re: How many people should I hire to lay sod?
Assuming all the work to the work to the ground has been done, laying down sod goes very quick. Guys will likely spend more time moving the sod from the pallet to the lawn area than actually putting it down. So try to have the pallets placed as close as possible to where they are going to be used.
2 guys should be plenty. Make sure they (or you) walk on the sod to seat it into the dirt, particularly along the edges.
SPS-1 is online now   Reply With Quote
Old 08-07-2017, 06:30 PM   #3
jlhaslip's Avatar
Rewards Points: 708
I would hire 3 so there would be one guy in charge of Adult Beverages.
SPS-1 and Nealtw like this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-07-2017, 08:43 PM   #4
Not sure where you are located, but around here, early September is considered to be a better time to start a lawn than early August.
Msradell and Bud9051 like this.
Old 08-08-2017, 05:30 AM   #5
Naildriver
chandler48's Avatar
Rewards Points: 4,250
If you were around here, I would offer my sympathies at hiring anyone for anything. No one wants to work, especially hard. I should think hiring 2, plus you supervising would work well. Pay them well for short term work like that. They will appreciate you more for it, and you will have an automatic labor pool to draw from if you ever need work done again.
Bud9051 and mark sr like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 08-14-2017, 09:39 AM   #6
Rewards Points: 576
Why hire from Craigslist ? Did you ask about installers or check the bulletin board at the sod supplier ? Make sure at least ONE helper has done this before.....a lot. Lots of little tricks involved to get edges tight and to trim odd dimensions. Re-grade as you go, because footprints will appear in your path. Dunno about stepping on sod...some like to use a roller with 1/3 water in it. Is there some 5-10-10 already in the soil ? Hope so.
Does not have to be laid in 4 hours....you can wet/mist sod occasionally. Did you get thick sod ? You can unroll sod, water and keep overnight....and roll back up for install next day. Hopefully, you can unroll a piece or two from each pallet before accepting delivery. Yellow color is not good.
Cedrus is offline   Reply With Quote
Trafficmaster Allure - Underlayment? HuskySkull Flooring 47 06-11-2014 04:04 PM
All of those low-life dirtbag people advertising websites in the forum... J187 Off Topic 3 05-03-2007 11:31 AM
People on here fishing... DaveH General DIY Discussions 19 08-02-2006 12:55 PM
