How Many Drippers On 1/2" Drip Line - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-19-2015, 09:39 PM   #1
Rewards Points: 184
How Many Drippers on 1/2" drip Line
Can anyone tell me if 25 drippers is too many for a 1/2" line connected to a faucet running off city water. thanks
Splais is offline   Reply With Quote
Old 08-19-2015, 09:58 PM   #2
Rewards Points: 1,488
90840 Drops of water in 1 Gallon, depending on who you ask, so just count the drops and do the math.
Old 08-20-2015, 06:51 AM   #3
Rewards Points: 6,997
A 1/2 hose will move approx 840 GPH with normal city pressure. Drippers are rate in GPM or GPH. You do the math but I am going to stick my neck out and say you will be fine.
flexpvc.com/WaterFlowBasedOnPipeSize.shtml
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
oh'mike (08-20-2015)
Old 08-20-2015, 08:08 AM   #4
Retired Moderator
Rewards Points: 7,174
Well,I am confused.
Are you talking about the little water tubes with the lead weights that are used to water plants?
Old 08-20-2015, 08:46 AM   #5
Rewards Points: 184
I'm talking about the 1/2" poly tubing you run 1/4" drip line off of to the plant and then attach various kinds of adjustable drippers or sprayers to the 1/4" line.
Old 08-20-2015, 03:21 PM   #6
Mike a small barb is inserted into the 1/2" line and a 1/4" line runs to the emitter. Here is a picture of one.
Photo credit: www.irrigationdirect.com/
Colbyt
Old 09-02-2015, 12:06 AM   #7
Rewards Points: 38
I've got at least 30 drippers on one of mine going at 1 gal per hour each. It works fine and I wouldn't think twice about adding on to it.
crf731 is offline   Reply With Quote
1/2" vs 1/4" drip line vs 1/2 Poly with Emitters Splais Landscaping & Lawn Care 5 07-22-2015 10:35 AM
Condensate Drain Line & Pan Problems hobbzilla HVAC 10 08-04-2014 11:31 AM
How to replace your clothes line Fantastic Remodeling 5 08-17-2013 09:17 AM
2 1/2" copper drain line fred54 Plumbing 10 11-16-2012 04:35 PM
Is this normal/correct? Shingles overhanging drip ege by 1/2" or so diymonkey Roofing/Siding 11 12-08-2008 08:29 AM
