How To Make Stepping Stones Not Slippery? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-17-2015, 01:36 PM   #1
Rewards Points: 4
How to make stepping stones not slippery?
We have beautiful stained glass set in concrete stepping stones in our yard. They unfortunately are slippery as heck. Can anyone suggest some sort of solution that can be applied to give them texture for traction?
ABZAmom is offline   Reply With Quote
Old 08-17-2015, 03:09 PM   #2
JUSTA MEMBER
Rewards Points: 4,080
I have two ideas, unfortunately neither one is pretty.
1 Get some stair tread tape, sold at the box store, it comes in different widths, it is a peel and stick item that looks similar to garnet shingle material, made for stair edges to give them some non-slip traction.
2. Try some glass etching acid paste, sold in the hobby department for frosting glass designs on windows, or any other glass surface. Remember to clean it up very well after using as it is ACID and will burn you and everything it gets on.
ED
de-nagorg is online now   Reply With Quote
Old 08-17-2015, 09:21 PM   #3
JUSTA MEMBER
I remembered a third alternative.
There is a device similar to an air brush, that uses a silica compound instead of paint to etch glass also, the only drawback is you still have to clean up the blasting agent and the blasted particles.
And it takes an artistic skill to make detailed designs, but you are artistic aren't you.
You put stained glass into a walkway.
ED
Cap stones instead of bricks for retaining wall diy_derek Landscaping & Lawn Care 6 11-03-2012 12:50 PM
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 10:41 AM
How to make a custom floor transition chuckp27 Flooring 9 12-02-2011 10:48 AM
best way to make a small water tank? Red Squirrel Plumbing 22 05-01-2011 06:12 AM
Easiest stones use to lay outside? KUIPORNG Landscaping & Lawn Care 6 06-27-2006 08:37 PM
