How Long Can Top Soil Sit Before Seeding - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 05-26-2017, 05:45 PM   #1
Rewards Points: 79
How long can top soil sit before seeding
I'm looking to plant grass, and had the top soil delivered Tuesday (May 23). It's 2 truckloads and I've covered it with tarp. Due to scheduling changes, I'd like to wait until Sun May 4 before planting the grass seed. Is it OK to leave the topsoil that long?
cgott42 is offline   Reply With Quote
Old 05-26-2017, 06:26 PM   #2
Rewards Points: 17,912
Re: How long can top soil sit before seeding
Just have to be missing something, delivered to me is they backed up and delivered it in a pile and has not been spread out where it needs to be, correct me If I'm wrong.
Why cover it?
Even if it's been spread out why cover it?
It's not going to go bad.
Bondo likes this.
Old 05-26-2017, 06:55 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... It can sit there til 'ell freezes over,... it's dirt,....
It just gets harder to dig as it settles,...
Bondo is online now   Reply With Quote
Old 05-26-2017, 06:55 PM   #4
Rewards Points: 898
It's been here for hundreds of years at least, a few more days won't make a difference.
BIG Johnson is offline   Reply With Quote
Old 05-26-2017, 06:56 PM   #5
Rewards Points: 898
And full of weeds.
Old 05-26-2017, 06:57 PM   #6
Rewards Points: 898
Rent a slit seeder, it's by far the best way to plant new grass. Assuming a northern mix.
Old 05-28-2017, 09:09 AM   #7
Rewards Points: 79
Thanks.
What does a slit seeder do more than a regular spreader. (yes northeastern)
Also, someone mentioned to seed twice - when do I put the 2nd round of seeds? Is it necessary?
Old 05-28-2017, 10:10 AM   #8
Rewards Points: 4,236
Are you concerned about it losing its nutrients? ( innate fertilizer)
That should be fine.
Reading up on putting in a lawn should help you relax about it. Sunset Western Garden Book is great. It depends on where you live, but once you have the right seed, grass is grass, & you can always add more. I always think that if we consider all potential problems & plan for them, then things usually go fine.
Nik333 is online now   Reply With Quote
Old 05-28-2017, 05:46 PM   #9
Rewards Points: 898
Thanks.
A slit seeder places the seed just below the surface. Basically it puts it into the soil where the soil will hold moisture. If you put it on top the moisture evaporates in minutes of shutting off the water. Some people use hydro mulch but you have to lay that on really heavy ($$$$$$) or its gone in a few days.
Some recommend spreading the seed and raking the dirt over it but that's hit or miss and you'll likely end up with 90% of your seed not germinating.
Old 05-28-2017, 05:59 PM   #10
Rewards Points: 1,496
Using a glass jar, do a soil test to determine what you were sold and delivered. Fill the jar about half full with dirt and add water to about 80-90 percent full . Shake vigorously for a couple of minutes and leave set over night.
SeniorSitizen is offline   Reply With Quote
Old 05-28-2017, 09:24 PM   #11
Usually Confused
lenaitch's Avatar
Rewards Points: 2,168
I think most people cover a pile of topsoil to prevent it from washing away in a heavy rain and to keep airborne weed seeds from germinating.
"Seeding twice" might mean to seed in both directions (1/2 rate each). Many find it helps to ensure even coverage.
bob22 likes this.
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Nik333 (05-29-2017)
Old 05-29-2017, 06:19 AM   #12
Rewards Points: 898
I agree. Seed in a crisscrossing pattern at the same time. Especially when slit seeding. And most importantly, buy high quality FRESH seed.
Nik333 likes this.
Old 05-29-2017, 11:44 AM   #13
How do you know it's fresh?
Old 05-29-2017, 12:44 PM   #14
Rewards Points: 898
There should be a date on the bag.
Nik333 likes this.
The Following User Says Thank You to BIG Johnson For This Useful Post:
Nik333 (05-29-2017)
Old 05-29-2017, 01:37 PM   #15
And thanks for the plumber's wrench idea!
HELP seeding 1 acre bare lot Daugela Landscaping & Lawn Care 3 04-22-2014 09:45 PM
Soil Stack Arrangement- with PICS! project_guy Plumbing 8 12-14-2012 07:36 AM
how long is too long for more floor poly? LidoGirl Painting 12 09-09-2012 07:36 AM
Compacting wet/muddy soil for paver/wall base BrandonC_1972 Landscaping & Lawn Care 0 07-04-2012 10:34 PM
Soil prep for additives and slope/drainage for new sod kevinf. Landscaping & Lawn Care 0 08-28-2011 02:55 PM
