How To Kill Weeds From Coming Up Through Paver Blocks? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By stick\shift
  • 1 Post By joecaption
  • 1 Post By CodeMatters
  • 1 Post By w0j0
Old 09-26-2018, 11:33 PM   #1
Rewards Points: 2,420
How to kill weeds from coming up through paver blocks?
Location is Miami, Florida.
I have weeds coming up through the paver blocks and is a bit out of control. It didn't use to do this last few years but for some reason, they are coming up left and right.
Any idea what to do?
Use chemicals like Round-Up? Bleach?
Pressure wash?
miamicuse is online now   Reply With Quote
Old 09-27-2018, 01:40 AM   #2
Rewards Points: 4,170
Re: How to kill weeds from coming up through paver blocks?
As I mentioned on the other forum, there are products you could apply to kill the weeds but I want to add I would not use a pressure washer as you could force the media you have between the blocks out and eventually lead to some of them dropping down as a result of their base being eroded.
de-nagorg likes this.
stick\shift is offline   Reply With Quote
Old 09-27-2018, 02:43 AM   #3
JUSTA MEMBER
Rewards Points: 4,082
Never Pressure Wash them, unless you are prepared to re install them.
Those weed killers chemicals are adequate and will work.
Another method is to use a Propane Torch to burn them and their seeds, but be careful not to heat those pavers too much, they can POP out little divots, ruining their appearance.
There is a better product than Roundup, but I am "blanking" on it's name, , it is used in agriculture to kill weeds in a farmers field, they buy it in bulk and spray it with a tank pulled by a tractor.
Anybody remember what that is?
ED
de-nagorg is online now   Reply With Quote
Old 09-27-2018, 05:03 AM   #4
Rewards Points: 17,914
https://www.tractorsupply.com/tsc/pr...l?cm_vc=-10005
Brand does not matter, what you need to do is read the lable where it shows the amount of active ingredient.
The higher the number the better it works.
What I do is pull the grass and weeds as best I can by the the roots before spraying so I do not see a bunch of dead stuff left behind on top of the walkway.
de-nagorg (09-27-2018)
Old 09-27-2018, 05:56 AM   #5
Rewards Points: 1,586
For long term pre-emergent consider researching soil sterilizers. For short term post emergent application there are several products to consider.
Old 09-27-2018, 05:59 AM   #6
retired framer
Rewards Points: 20,734
You can control with vinegar but you may eventually get moss because of the acid content.
Nealtw is offline   Reply With Quote
Old 09-27-2018, 06:07 AM   #7
CodeMatters's Avatar
Rewards Points: 6,644
Every time I have near boiling water left over from potatoes or whatever,
I pour the water on weeds/grass growing between bricks, pavers, etc..
Kills them fast.
Nealtw likes this.
CodeMatters is offline   Reply With Quote
The Following User Says Thank You to CodeMatters For This Useful Post:
Fix'n it (10-02-2018)
Old 09-27-2018, 06:27 AM   #8
Try Ortho Groundclear. I would suggest weedkiller before pulling. If you don't get all the root most weeds will resprout, then you are pulling again.
Sent from my SM-G900V using Tapatalk
cmwhitmoyer is online now   Reply With Quote
Old 10-01-2018, 01:47 PM   #9
Rewards Points: 56
You can also try some Polymer Jointing Sand...it will solidify when wet and will REDUCE weed growth in the future
https://www.homedepot.com/p/SAKRETE-...0004/202070568
stacik84 is offline   Reply With Quote
Old 10-01-2018, 03:10 PM   #10
Rewards Points: 6
I used to put rock salt down on the brick paved sidewalk outside of a house I lived in up north. People thought I was crackers for salting my sidewalk in the summer... but no weeds. Cheaper and longer lasting than spray.
If that sounds like it will get tracked into the house, or you have pets, probably want to go the ground clear/round up route. Though the torch suggestion may be cheaper still (after the initial investment, of course) and probably just as long lasting.
w0j0 is offline   Reply With Quote
How much Roundup needed to kill lawn weeds? pman6 Landscaping & Lawn Care 19 03-14-2013 09:42 AM
Cold air coming through joist holes in concrete block foundation. Ptron Building & Construction 2 01-30-2011 04:29 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
Water coming in at base of foundation Ptron Building & Construction 22 08-09-2010 09:51 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
