How To I Make This Level? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By Nealtw
  • 1 Post By Rangerxlt
  • 1 Post By de-nagorg
  • 3 Post By Rangerxlt
Old 01-13-2019, 11:23 AM   #1
Rewards Points: 356
How to I make this level?
I have some patio stones at my front yard hose bib as shown in the photo. How do I make these stones reasonably level with each other? Not looking to spend a lot of money on a pad or anything like that. Mainly want to keep stones from sinking. What would I use underneath the stones.....something involving sand?
Rangerxlt is offline   Reply With Quote
Old 01-13-2019, 12:36 PM   #2
retired framer
Rewards Points: 20,602
Re: How to I make this level?
You can see with the crack in the concrete the fill was not compacted when this work was done. It might be better now, I would remove them and re level with sand and redo them and hopefully the ground has settled all it needs too.
Is that hole to the left a vent for a crawl space, I hope water does not run in there.
lenaitch likes this.
Old 01-13-2019, 10:41 PM   #3
Rewards Points: 356
No crawl space and no vent.That's just where the stucco wall extends beyond the foundation with no white paint. I'll get some sand and do it next weekend. Thanks Neal
Nealtw likes this.
Old 01-13-2019, 10:49 PM   #4
JUSTA MEMBER
Rewards Points: 4,060
While you're at HD getting a bag of sang, get a hand tamper also, then add a little extra weight to it, slip a barbell weight over the handle, for extra power, and tamp your new sand, and bedding level, this will help the pavers stay where you put them.
After placing the pavers and getting them level, place a carpet remnant over them as padding and tamp once more.
Unless you happen to rent or own a power tamper.
ED
Nealtw likes this.
de-nagorg is offline   Reply With Quote
Old 01-13-2019, 11:09 PM   #5
Rewards Points: 356
Thanks for reminding me about the tamping part, Ed. I'll probably improvise something for a tamper.
de-nagorg likes this.
Old 01-20-2019, 01:21 PM   #6
Rewards Points: 356
Completed this task this morning. Done.Thanks again
SPS-1, de-nagorg and Nealtw like this.
Laser level, sight level, or other level methods with high accuracy? viper Building & Construction 13 06-24-2016 10:35 AM
Sump water level pnorman55 Plumbing 18 03-21-2016 12:16 PM
Distribute A/C accross three level townhouse aerolulu HVAC 15 05-24-2015 03:08 AM
water level equalizing in sump pump basin? dmp Plumbing 21 04-13-2012 06:42 PM
Easy ways to make flooring transitions same level apex_predetor Flooring 0 03-17-2010 01:20 PM
