How Do You Connect SkyDrop To A Pump Start Relay (PSR)? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-07-2015, 11:03 AM   #1
Rewards Points: 12
How do you connect SkyDrop to a Pump Start Relay (PSR)?
For anyone who has experience with the SkyDrop Timer, Pump Start Relays, and/or connecting digital sprinkler timers to pump start relays....
I will connect the SkyDrop outdoors. I will need to use a Pump Start Relay. The Pump Start Relay will have two 24v wires out to the SkyDrop BUT there is no place to connect
those wires.
The SkyDrop power adapter uses a proprietary connector to plug into the SkyDrop's wall plate (beneath the bubble level).
How can I connect the SkyDrop to a Pump Start Relay so it can receive power? Any suggestions are appreciated.
etiennefamily is offline   Reply With Quote
Tags
controller , psr , pump start relay , skydrop , timer
Need help hooking up pool pump to relay switch and Intermatic mechanical timer. Ler0y Jenkins Electrical 18 05-16-2014 08:58 PM
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Giving a heat pump a jump start. Mr.Pappy HVAC 3 12-13-2009 07:59 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Irrigation pump relay RHR Electrical 5 08-23-2009 12:16 AM
