How Do I Prune Water Sprouts / Runners / Vertical On A Plum Tree? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Msradell
Old 03-05-2018, 08:14 PM   #1
Rewards Points: 474
Question
How do I prune water sprouts / runners / vertical on a plum tree?
Starting a new thread.
So, plum tree is several years old and the prior owner was in the habit of chopping every new vertical growth each spring. I don't think he did it last year. One neighbor suggests pruning only 1/3 of the older ones each year and the other neighbor suggests take it all off every year.
I also have an apple tree that does bear fruit and would want to prune that correctly as well.
Suggestions? Any on line guides, I like pictures!
Thanks!
Jim
UltraRed is offline   Reply With Quote
Old 03-06-2018, 04:50 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,328
Re: How do I prune water sprouts / runners / vertical on a plum tree?
Don't know why you started a new thread, but look at this if you need pictures. http://extension.uga.edu/publication...Woody%20Plants
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-06-2018, 11:59 AM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,224
Good link from Chandler. No doubt there are all sorts of online publications on this topic. A lot depends on the species of tree or bush. Different species can cope with different degrees of 'enthusiasm' when it comes to pruning or cutting back.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 03-06-2018, 01:44 PM   #4
Rewards Points: 1,590
The OP may have already decided DIY admins can take this site and shove it.
Old 03-06-2018, 09:59 PM   #5
Msradell's Avatar
Rewards Points: 832
Question
Nik333 likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Nik333 (03-06-2018)
Old 03-06-2018, 11:12 PM   #6
Rewards Points: 474
1/3 of the runners or all of them? pros & cons? still trying to sort this out. thanks.
Old 03-07-2018, 04:18 AM   #7
Naildriver
chandler48's Avatar
Locate this year's growth (you can tell by the difference in the bark color) and cut the sucker 3 buds above it. That will give you this year's fruit and do away with quite a bit of extraneous growth. You won't hurt the tree, as they are quite vigorous.
Larry......
Old 03-07-2018, 08:13 AM   #8
Rewards Points: 474
Thanks Chandler48. So cut 3 buds above where the sucker leaves the branch it's growing from? Also this tree is kind of a mess, some suckers are a year or more old - same to them? I'm told there is no fruit on this plum tree as it's an "ornamental".
Hot water cross over mystery maroonw Plumbing 4 04-29-2016 05:14 AM
Salt based water softeners destroy septic? JPCheslock Plumbing 14 09-15-2015 08:13 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Small Yard, Tree Roots....? JayNYOne Landscaping & Lawn Care 6 11-13-2011 06:30 PM
