How To Calibrate Old Model Drop Spreader? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-03-2017, 03:43 PM   #1
Rewards Points: 133
How to calibrate old model drop spreader?
(Pls. don't tell me about getting a broadcast spreader. I prefer the drop spreader for accuracy.)
I have had this spreader forever....and Scotts won't help me with support.
I usually eyeball the settings but decided this season to recalibrate the settings. Problem: the old 1000 model does not have calibration marks on the bottom like the newer Acu..1000. And I don't have the manual.
Anyway, approximately how deep in cm or inches should the little triangle opening be at the default setting of 6? This info would do me just fine. Thanks.
Hossenfeffer is offline   Reply With Quote
Old 05-03-2017, 04:41 PM   #2
Rewards Points: 1,566
Re: How to calibrate old model drop spreader?
Count the revolutions you would rotate the drive wheel to travel 100 feet or meters. Jack it up with a catch pan underneath and rotate the wheel the predetermined revolutions. Weigh the product dropped each trial run and you'll soon have it right on the money for accuracy for 100 sq. ft./meters.
Old 05-03-2017, 04:59 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,210
I'm not sure "calibration" is the word I would use, but if setting 6 is one of 10 settings, I will assume that the settings are linear - or as linear as a mass produced spreader can be. You could measure the size/width/whatever of the opening when set to fully open, then set 6 to be 60% of that.
lenaitch is offline   Reply With Quote
Acceptable voltage drop at receptacles? dave11 Electrical 13 04-25-2017 09:58 AM
Drop gable stick build with lean to roof crecore Building & Construction 19 01-17-2016 03:02 PM
2 2x12 and 1/2 plywood nailed drop beam dmoney1234 Building & Construction 16 08-19-2015 10:39 AM
Can the hot wire be under tension in an overhead drop?? WillK Electrical 15 10-08-2011 01:40 PM
Service drop too low above garage WillK Electrical 1 09-19-2011 12:00 PM
