How To Calculate Amount Of Fill Dirt Needed For Slope - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By de-nagorg
  • 1 Post By homeimproverjoe
  • 2 Post By jlhaslip
  • 3 Post By homeimproverjoe
Old 04-03-2017, 07:25 PM   #1
Rewards Points: 616
How to calculate amount of fill dirt needed for slope
The fill area slopes in two directions. From zero fill on the left to 4 foot deep on the right side. Its 32 feet from left to right and 13 feet deep from front to back. Does there exist an online tool or formula that will allow me to get a reasonably accurate estimate for the yards of fill dirt needed? If it was a perfect cube, I understand I could multiply LxWxH to get the volume. So, since it slopes from zero, can I just divide the calculation by half to get the volume?
For that I get 32x13x4 = 1664
1664/2=832 cubic feet.
832/27=30 cubic yards
Does this sound right? If so, what would be a rought estimate of cost for 30 cubic yards of fill dirt delivered?
homeimproverjoe is offline   Reply With Quote
Old 04-03-2017, 09:58 PM   #2
JUSTA MEMBER
Rewards Points: 4,018
Re: How to calculate amount of fill dirt needed for slope
That's close to right, Math is sound, but now you need to allow for the fact that fill is loose material, so when you tamp it down you are going to need 10 to 25 % more. Depending on the fill you get and the looseness in it.
Are you going to install a retaining wall first, or at all?
ED
homeimproverjoe likes this.
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
homeimproverjoe (04-04-2017)
Old 04-04-2017, 06:41 AM   #3
Rewards Points: 616
ED
Thanks Ed. I'm strongly considering it. Along the right side, staggered from 4 foot where it meets the wall, down to zero 13 foot out from the wall where it meets the slope of the existing yard and creates the drainage path for runoff.
I found the cost of retaining wall notched pavers to be fairly economical.
I'm also considering just sloping the wall off to the right instead of using retaining wall. It would appear more natural but require much more fill dirt.
Old 04-04-2017, 07:02 AM   #4
Rewards Points: 616
To simplify the calculations, I used a perfect cube. However, the fill will only extend level about 4 feet from the wall (to form a level flower bed for plantings). It will then gently slope down to meet the existing reverse slope of the yard appx 13 feet from the wall. This will create a V shaped runoff path that will divert water to the right side of the house.
Based on that, I'm expecting I should have enough overage in the calcs to allow for tamping of the dirt.
Along those lines, I'm considering renting a Bobcat MT85 or MT55 to move the dirt from the dump site to the location. Can I tamp the dirt with the tracks or do I absolutely need a separate attachment or machine?
Old 04-04-2017, 08:01 AM   #5
JUSTA MEMBER
What plans are there for erosion control?
If you don't plan now, all your work will be washes into the back yard, and lower area.
I would use some large rock in the base to keep water in control.
Those wall blocks are great to work with, a little heavy after a few hundred, but really stacks nice.
They need a solid foundation to be permanent, or they will slide away too.
Is there room to maneuver the Bobcat easily, it's gonna tear up ground turning around.
ED
Old 04-06-2017, 07:09 AM   #6
Rewards Points: 616
The first 4 feet from the wall will be bedded plants with mulch beds. The remaining 9-10 feet of the ground will be sodded zoysia.
Interesting. Do you mean gravel for drainage or boulders for mass/fill? I have some very large embedded rock/boulders on the rear of the property. Could pile some in the deepest part of the fill near the right rear section. For drainage, there will be dimpled waterproofing membrane attached to the wall with 30 feet of interconnected NDS 4-in x 10-ft Corrugated French Drain Pipe along the wall base for drainage out to the right side. https://www.lowes.com/pd/NDS-4-in-x-...n-Pipe/3136611
Those wall blocks are great to work with, a little heavy after a few hundred, but really stacks nice. They need a solid foundation to be permanent, or they will slide away too.
By calcs, I need appx 120 blocks. For a base, plan is to level the wall base path twice as wide as the blocks with the first course below grade, then stack courses from there to form a pie shaped wall that goes from 4-6 foot at the wall down to zero 13 feet out in front at the drainage channel.
Should be. I have a skid steer guy coming by this week for a quote.
Old 04-06-2017, 08:37 AM   #7
JUSTA MEMBER
That sounds like a good plan, and getting a local operator, engineer involved is great.
They will be better able to advise you on what will be best for your project, they have eyes on the slope, as well as knows how to run the bobcat, and do this to your expectations.
I was wondering if you were planning on using any waterproofing membrane on the basement wall, now I know that you are.
ED
Old 04-06-2017, 10:43 AM   #8
Mike Milam's Avatar
Rewards Points: 174
Just one thing that comes to this DIYer's mind. You might consider hiring someone with a bobcat as the cost of renting a bobcat and if not use to using one, renting may be near the same cost. Around here they charge by the hour as a rule.
Mike Milam is offline   Reply With Quote
The Following User Says Thank You to Mike Milam For This Useful Post:
homeimproverjoe (04-06-2017)
Old 04-06-2017, 01:03 PM   #9
Rewards Points: 616
Thanks Mike, I'm getting a few quotes from some local operators. The cost for a Dingo is $209 a day from local Home Depot. Larger bobcat machines go for about $300/day.
Going rate for skid steer guys here is $60-$75 an hour with $250 minimum. I'd expect a skilled operator could get in and out in a few hours and do it right for about the same as a day's Bobcat rental.
Mike Milam likes this.
Old 04-06-2017, 01:06 PM   #10
jlhaslip's Avatar
Rewards Points: 708
As well, the Bobcat operators might have a source of fill dirt and/or topsoils.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-07-2017, 08:51 PM   #11
Rewards Points: 616
Just met with the first guy and sure enough, he indicated that he could get fill dirt cheaper than my original quote. Estimated 4-8 hours for the complete grade and fill job.
jlhaslip, de-nagorg and Mike Milam like this.
Old 04-09-2017, 08:25 AM   #12
Engineer
MikeFL's Avatar
Rewards Points: 182
What's the objective?
A flower bed. Anything else?
That's a tremendous slope to alter and/ or a big force on whatever you build for a wall.
Is there a full basement behind that wall?
Could you get by with a flower bed that spans the center 1/3 of the wall? That may reduce your costs 80%.
I'd keep that tree at least 20' from the building. Trees and buildings don't get along very well. From roots and branches to rot and leaves on the roof, the greater the distance the better. You may want to consider 30' distance.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
MikeFL is offline   Reply With Quote
Old 04-09-2017, 08:57 AM   #13
Rewards Points: 616
Hi Mike, it will just be a 3-4 foot bed for foundation shrubs under the windows. It will be level across the wall until the midpoint of the last window on the right where it will gradually slope down to grade on the right. I will plant monkey grass on the slope to hold the soil. The trees will be planted out in front of the monkey grass slope area. Pics below...
Old 04-09-2017, 09:05 AM   #14
Rewards Points: 576
How about some daylily/hemerocallis to REALLY hold the slope together....
Cedrus is offline   Reply With Quote
The Following User Says Thank You to Cedrus For This Useful Post:
homeimproverjoe (04-09-2017)
Old 04-09-2017, 09:17 AM   #15
Rewards Points: 616
Thanks for the suggestion and feedback. I chose the monkey grass b/c we already have lots of it growing in the area where the slope meets grade so I know it grows well in that area and is holding slope well currently.
There is also a considerable amount of it on the left side bed area where we will be excavating. It will have to come up so I was thinking to preserve it and transplant it over on the right side on that new slope.
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
How to calculate how much rock fill and asphalt to order? Negativecreep0 Landscaping & Lawn Care 5 04-08-2010 09:08 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
how to calculate box fill ponch37300 Electrical 24 01-28-2009 09:48 AM
Is there a proper fill dirt for grading? Sonabi Landscaping & Lawn Care 2 04-18-2008 11:23 PM
