How To Alleviate Spot Flooding? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-29-2018, 10:21 AM   #1
Rewards Points: 160
How to alleviate spot flooding?
In the middle of a couple days worth of rain and noticed that the water tends to flood in this one spot. I just did some work in the garage to level the slab and im realizing now what caused it to sink in the fist place.
Im due for a new driveway but the landscaping was just redone. Would having a new driveway installed with a proper slope improve my situation? Im hoping to avoid some flooding into my garage....
https://imgur.com/a/HncRj7m
mathbishop is offline   Reply With Quote
Old 11-29-2018, 10:31 AM   #2
Rewards Points: 1,512
Re: How to alleviate spot flooding?
The area to the right of the garage door will need to be included in the drainage plan and a berm wall from the building corner with drain pipes in the wall near the top of the wall for any area to the right of that which may not be included in the drainage plan.
Old 11-29-2018, 01:42 PM   #3
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,234
sump pump - like in a basement.
will keep it dry until you can do the corrective landscaping.
Johnny_inFL is offline   Reply With Quote
Old 11-29-2018, 04:28 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,....... Which way is "Downhill" in yer picture,..??
What's just outa the frame, left, 'n right,..??
The driveway needs to be Lowered, in the downhill direction, to increase pitch, which increases flow Away from the garage,.....
Old 11-29-2018, 06:22 PM   #5
Rewards Points: 160
Ended up getting a cheap pump from harbor freight, had to clean it out a couple time due to sand but it got the job done.
Old 11-30-2018, 08:06 AM   #6
Rewards Points: 2,800
Reviewing the bidding:
A. Re-regrade the lawn to the right to let water drain downhill away from the house.
B. Tear up the driveway, don't just add a layer of asphalt. Grade the bed down away from the house so paving maintains that downhill..
C. Install a nonporous sided pit with surface grill opening and permanent sump pump to catch the water that would otherwise pond up as seen in your picture.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
move an air duc to fix hot spot? Noltian12 HVAC 5 08-02-2018 01:43 PM
What to do about a damp spot on ceiling? hockeyp21 General DIY Discussions 15 06-07-2014 06:02 AM
much hotter spot on floor BlueBSH Building & Construction 8 06-20-2011 10:08 PM
Flooding in Wood Foundation mhp8982 Building & Construction 14 03-09-2011 01:15 PM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 02:46 PM
