Hose Fitting Leaking - Quick Fix? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 05-22-2018, 05:27 PM   #1
Rewards Points: 44
Hose fitting leaking - quick fix?
Hey all - I have a portable 14 gallon gas tank that I just got.
I attached a hose to it, and cranked the hose fitting as tight as I could get it, but it still feels like there is 'play' on the connection, and I certainly don't want to be leaking gas.
If I were to get some more of those 'o-rings' that fit inside the connection, would that help make it tighter? How many of those could I get away with?
Here is what I am talking about:
https://www.homedepot.com/p/Ray-Padu...CIOR/205172388
lordx2 is offline   Reply With Quote
Old 05-22-2018, 05:41 PM   #2
Rewards Points: 1,906
Re: Hose fitting leaking - quick fix?
I do not think those washers will last long in hoses with gasoline use.
Gregsoldtruck79 is offline   Reply With Quote
Old 05-22-2018, 05:44 PM   #3
Rewards Points: 44
Ok. But is the idea sound? I can always get gasoline rated washers.
Old 05-22-2018, 05:44 PM   #4
Rewards Points: 1,518
Please stop attempting to adapt water hose to a gasoline tank before you hurt yourself, someone else or burn the place down.
Old 05-22-2018, 05:46 PM   #5
Rewards Points: 44
It is a gasoline hose (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1)....
so... back to the original question...
Old 05-22-2018, 05:56 PM   #6
retired framer
Rewards Points: 20,478
I would try an auto parts store for washers that are made for gasoline.
Old 05-22-2018, 06:00 PM   #7
Rewards Points: 44
Ok Neal, I will do that - but should the idea itself work?
Can I have 2 to 3 of those type (OF GASOLINE RATED WASHERS) installed in the female end?
Old 05-22-2018, 06:00 PM   #8
Ok, so i'm ignorant and can't tell the difference in the 2 links you provided.
I was told I was born in the dark, but it wasn't last night.
Go ahead with the original question but before proceeding have someone besides you keep the fire department number handy. You may not be in any condition to make a 911 call.
Old 05-22-2018, 06:01 PM   #9
Rewards Points: 7,558
I am no expert on fuel lines, but that garden hose washer is definitely the wrong item to use.
Looking at the Apache web site, that seems to be standard tapered pipe threads, which would seal with fuel rated pipe dope.
https://www.apache-inc.com/CMS/apach...257EED00523C0D
SPS-1 is online now   Reply With Quote
Old 05-22-2018, 06:03 PM   #10
...No.
Old 05-22-2018, 06:04 PM   #11
Rewards Points: 44
Thank you for the relevant response!
I don't know if it is the threads, or the fact that I just can't tighten the fitting enough to have the back touching the hose - leaving a gap there for fuel to spill out of. That is why I was thinking the washers, to make the amount of tightening required less.
Old 05-22-2018, 06:05 PM   #12
My ignore list is getting longer. I'm wondering if there is a maximum membership.
Old 05-22-2018, 06:07 PM   #13
Rewards Points: 44
If you didn't click the links, I think it is YOU who doesn't know what is going on....
I have a gasoline tank... and a gasoline hose.... Just trying to make sure they are tightly fit together so no leaking occurs...
You can take your snark elsewhere!
MTN REMODEL LLC likes this.
The Following User Says Thank You to lordx2 For This Useful Post:
MTN REMODEL LLC (05-22-2018)
Old 05-22-2018, 06:10 PM   #14
retired framer
Perhaps a question for them.
https://www.apache-inc.com/CMS/WSCen...HBD-97RRM7.pdf
Old 05-22-2018, 06:14 PM   #15
Rewards Points: 44
I think I may give them a call in the morning - thanks!
Hopefully that cranky old dude doesn't work there!
MTN REMODEL LLC and Nealtw like this.
water line to icemaker on fridge leaking from connection Mkr88x Plumbing 12 09-15-2016 01:30 PM
leaking cpvc 3/4 ball valve, quick fix? klip Plumbing 4 02-21-2016 07:33 PM
Drain hose leaking supermex79 Plumbing 4 05-17-2011 07:19 AM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
Can this leaking fitting be rescued? ac30boy Plumbing 8 02-01-2009 10:07 AM
