Hints /suggestions On Leveling Wall Base - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-29-2015, 08:45 PM   #1
Rewards Points: 30
Hints /suggestions on leveling wall base
InstaLling " stonewall select" retaining wall. They're 12 deep, 16in wide and 8in high block. Ea weighs 65lb, is hollow core which requires to be filled. Everywhere I looked, including the vendor and whoever the body is that makes the recommendations on such things (I'm drawing a blank and can't remember out for the life of me) recommends 3/4 stone with no fines. This make leveling the block much harder! Anyone have any recommendations/suggestions on making this a little easier?
Askin is offline   Reply With Quote
Old 09-30-2015, 09:28 AM   #2
Rewards Points: 297
I feel your pain. Even after several passes with a plate compactor, the 3/4 gravel base layer recommended by our manufacturer and dealer made getting the first course leveled out tricky. One piece of gravel could make things really difficult. We ended up using a very fine layer of granite sand on top of the gravel where needed to assist with setting the first course level. Even using the sand, it took the better part of a day to get the first course set (we ended up +/- 1/4" across the 30 linear feet of base course). Went fast after that though.
Something like "road base" or "crusher run" compacts more tightly and leaves a better surface, but like you I was following manufacturer guidelines. We've had no trouble with shifting or settlement in the couple years the wall has been there.
red92s is offline   Reply With Quote
Old 09-30-2015, 11:26 AM   #3
Rewards Points: 30
Did you compact the granite sand as well?
Is it similar to drive dust at all?
Did you get it at a big box type store?
I know it's only the first row on the pic, but it looks really good! Precise, symmetrical turns on both sides. That's pretty much what I'm looking to do. Hope comes out as well!
Old 09-30-2015, 11:28 AM   #4
Rewards Points: 30
Meant stone dust. Dam spell check!
Old 10-07-2015, 02:53 PM   #5
Rewards Points: 297
Yes, it was paver sand from a big box store. No need to compact it really, as it was such a thin layer. Sand does not really compact, since all the grains fit so tightly together to begin with.
I laid the curves out by putting a rebar stake at my center points and using a string line and marking paint to draw them out. We had a nice tripod laser level with a reciever which helped a lot getting the trench level.
Old 10-07-2015, 03:59 PM   #6
Rewards Points: 6,989
Like Red, I always use crusher run then a thin layer of rock dust (class I) and finally maybe a 1/4" of sand for the final level. All the work goes into the first course. Get it right and the rest is easy. I use water and a hand tamper to compact a couple of inches at a time.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Plastic shower base and concrete / leveling issue JoTeeBee Kitchen & Bath Remodeling 2 06-17-2011 07:46 PM
Building partition wall behind base cabinets bluefitness Building & Construction 3 11-09-2010 06:49 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
