Help With A Stihl Trimmer - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-13-2016, 09:49 PM   #1
Rewards Points: 424
Angry
Help with a Stihl trimmer
I have a gas powered Stihl string trimmer that I can't get running well. It of course ran great the first season I bought it, but now it won't. I made sure that I drained the gas when I stored it, and have since only used the pre-mixed Stihl branded fuel. What happens is when I eventually get it started, and pull the trigger, it just bogs out and dies, similar to a lawn mower that you don't let warm up for a minute before engaging the blades.
I have let it warm up, choke on, choke off, ensured air filter is clean. I haven't gotten the courage to take apart the carburetor though. My local hardware store told me to just buy a new carburetor. Thoughts?
PS: I'm about sick of gas lawn tools. Aside from my trusty honda mower, everything else gives me trouble. I may just switch to battery powered stuff.
clawlan is offline   Reply With Quote
Old 03-14-2016, 04:04 PM   #2
Rewards Points: 46
Re: Help with a Stihl trimmer
The guys over as http://www.lawnmowerforum.com/forum.php are great. Try posting in the Stihl sub-section.
afrig is offline   Reply With Quote
The Following User Says Thank You to afrig For This Useful Post:
clawlan (03-14-2016)
Old 03-14-2016, 04:13 PM   #3
Rewards Points: 424
Thanks for the tip. After doing a bunch more googling/youtubing, it seems that a popular issue is the muffler getting clogged. It's just a cylindrical metal mesh cylinder, like an over-sized thimble. I might take a look at this this weekend.
Old 03-14-2016, 06:02 PM   #4
Rewards Points: 188
Try fiddling with the choke while it's running at full power. If you can get it to run smoothly, then replace the carb. I had a similar issue with an Echo blower. Tried a bunch of things including the exhaust mesh. Finally replaced the carb and that fixed the problem.
Dan
djlandkpl is online now   Reply With Quote
Stihl trimmer williamdarrell Tools 7 10-03-2012 09:34 AM
Stihl string trimmer feed ... Fix'n it Tractors & Mowers 7 05-02-2012 10:47 AM
Trimmer Revs but Head won't spin leichte Landscaping & Lawn Care 1 06-21-2011 03:16 PM
Stihl vent tripleup05 Landscaping & Lawn Care 3 05-05-2011 11:10 PM
Repair help w/ a cordless trimmer kennykenny Tools 6 06-28-2009 08:20 PM
