Help With Retaining Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-18-2018, 12:03 PM   #1
Help with retaining wall
Hello all, thank you in advance for your input. I want to build a 90 degree corner retaining wall to flatten out a portion of my back yard a little bit. The wall will be about 2 feet tall. Since I live on a slope, should I worry about installing a drain pipe for a wall not that tall? And if I should, how would I drain it to daylight, since the corner is the lowest point? Thanks for your advice.
BCdude is offline   Reply With Quote
Old 03-18-2018, 04:32 PM   #2
Rewards Points: 1,222
Re: Help with retaining wall
A little bit of stone (golf ball size approx.) behind the wall should suffice. This way the wet dirt isn't being pushed against the wall, the water will trickle down through the stone rather than pushing on the wall. If it is extremely wet, you could add a few weep holes in the wall. A 2 ft wall, you could easily straighten up later if something goes wrong.
CrazyGuy is offline   Reply With Quote
Old 03-18-2018, 05:00 PM   #3
Guapo
Rewards Points: 11,950
How deep below grade do you plan to go?
Guap0_ is offline   Reply With Quote
Old 03-21-2018, 06:19 AM   #4
Rewards Points: 4,430
In this link you will find lots of information as well as the plans to build it
The site no longer has the DIY.....
But you could come back here if you have any questions.
There's plenty of people here that can help.
https://www.familyhandyman.com/searc...aining%20walls
You will see...
And much more....
ron45 is online now   Reply With Quote
Replace Collapsed 4' Retaining Wall With Dirt Slope? gunner666 General DIY Discussions 4 08-07-2014 10:09 PM
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 04:45 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 11:34 AM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 02:32 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
