Help- New Grass Not Filling In - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-23-2017, 02:12 PM   #1
Rewards Points: 79
Help- new grass not filling in
I planted grass seed about 4 weeks ag. The back of the yard is coming in nicely, but the front has come in somewhat but looks like a severly balding man.
I watered every day 3 x day for 30 mintues for the first 2 weeks, and after that have watered 30 min 1x/day
How should I help it?
Pictures attached and below
Help- new grass not filling in-front1.jpg   Help- new grass not filling in-front-closeup-1.jpg   Help- new grass not filling in-font-closeup-zoom.jpg   Help- new grass not filling in-back.jpg
cgott42 is offline   Reply With Quote
Old 07-23-2017, 03:05 PM   #2
RRH
Rewards Points: 1,336
Re: Help- new grass not filling in
Depends on what part of the country and grass type.
In my area mid Atlantic. Most places actually sell more grass seed in the spring and early summer. Even when it is only suppose to be planted in the fall.
Spring the fescue is not going to be mature enough to make it thru our summers. No matter how much water the heat will get it.
RRH is offline   Reply With Quote
Old 07-23-2017, 05:39 PM   #3
Rewards Points: 79
north east (though has been hot)
Shoudl I use a spread seeder and plant more seed?
Old 07-23-2017, 07:31 PM   #4
RRH
So you are planting a cool season grass in the summer instead of during the fall when it should be planted.
Save your seed. If you water it perfect you may get a lot to come up. But then it wont have enough root growth to make it thru the heat of rest of the summer.
Old 07-23-2017, 08:12 PM   #5
Rewards Points: 79
Being that I've already planted, how do I help it make it through the rest of the summer?
Old 07-23-2017, 08:59 PM   #6
concretemasonry's Avatar
Rewards Points: 2,716
In the first picture, I see what looks like a drainage pattern. - Could the seed have been washed away, rather than grab hold due to the 3x a day watering for for 30 minutes?
If the surface was not prepped or loosened it does not take much to wash it away.
Does the the back yard have the same slope and surface?
Dick
concretemasonry is offline   Reply With Quote
Old 07-23-2017, 09:29 PM   #7
Msradell's Avatar
Rewards Points: 826
Don't waste anymore grass seed now. Late until about 1 September and replant then. Early fall is the best time to plant all the early spring, early April, is to bed in your part of the country. New grass needs to become well-established before the hot weather hits.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 07-24-2017, 01:30 PM   #8
Rewards Points: 4,170
90 minutes of water a days seems excessive - you want to keep the seed moist but not damp. I agree you may have washed a lot of it away.
Furthermore, I agree with the criticism of your timing; put this off until the heat of summer breaks, likely the end of next month.
stick\shift is offline   Reply With Quote
Old 07-25-2017, 10:35 AM   #9
Rewards Points: 44
Ditto on the timing advice. Plant in September. It will keep growing as long as the daytime temperature reaches 50. That could be a solid three months. Then in the Spring you will get another three months of growth before you hit the hottest part of the year. When watering more is not necessarily better. If the seed is sitting in a puddle after watering it was too much and it could rot.
abrowning is offline   Reply With Quote
help bermuda grow into patchy spots denemante Landscaping & Lawn Care 5 05-28-2014 10:06 AM
Synthetic grass, anyone have experience w/ it? NewHomeDIYGuy Landscaping & Lawn Care 8 03-05-2013 03:35 PM
How to identify lawn grass types findlay70 Landscaping & Lawn Care 1 07-06-2010 08:10 PM
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 10:53 AM
