Help Constructing Drainage Swale - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Bondo
  • 1 Post By Drachenfire
Old 02-23-2018, 10:18 AM   #1
Rewards Points: 207
Help constructing drainage swale
I have attached a picture of the area I need help with.
Backstory:
I built an addition off the back of my house (towards the drainage slope that goes the other way). The ground was already pretty close to the siding and now they require 8" from siding to earth. The normal slope of the ground would bring into the foundation at about 3".
I need to dig down 5" around the foundation and somehow build a swale that will direct the water around the back of the house to the side and out the front. The picture shows a top view and side view of the area.
If I missed anything pertinent let me know. I'm in CA and under permit and not sure what materials would be needed to accomplish this. Can this be drain tile or is it just a ditch carved in the ground? I also want to install a deck over this area.
wease is offline   Reply With Quote
Old 02-23-2018, 10:58 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,244
Re: Help constructing drainage swale
Basically a swale is just going to be a regrading.... landscapers can certainly help with a little bob or back-hoe in there.... I can't tell how much dirt you have to move.
Your BO can advise if a concrete pad way along your home can be employed such that you only need 2" below slab grade, rather than 8....(I thought it was 6)
MTN REMODEL LLC is offline   Reply With Quote
Old 02-23-2018, 02:52 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... A Swale is a barely noticeable trench dug into the ground that continuously falls away from it's high point,....
Could be done with a shovel, pickax, rake, 'n wheelbarrow, or a bulldozer,....
Or anything in between,...
mark sr likes this.
Old 02-23-2018, 03:10 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,182
As the other lads have said, a swale is just a wide, shallow, gradual depression that slopes to a centre then slopes to where you want the water to go. It should be wide and shallow enough that you could run a lawn mower over/through it. Ideally, you should want it about 6' away from your foundation - and the grade sloped from the foundation to the swale - and keep any changes of direction nice and gradual, just like in your diagram.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 02-23-2018, 03:11 PM   #5
retired painter
Rewards Points: 1,776
Think of it as a ditch but without steep sides, blended smoothly into the rest of the terrain so you can easily mow it.
mark sr is offline   Reply With Quote
Old 02-23-2018, 06:35 PM   #6
Rewards Points: 207
Ok. I just don't think I can move that much dirt. Hoping I could do something closer to the foundation. Like within 2 feet. Digging any more than that would require a LOT of dirt removal and machines. Is there another way to do this? Thanks for the help so far.
EDIT: Also, I want to build a deck over this area.
Old 02-24-2018, 06:10 AM   #7
retired painter
A narrow ditch will likely work but it won't look as nice and could be a trip hazard. I suppose you could fill the ditch with big rock.
Old 02-24-2018, 07:02 AM   #8
JUSTA MEMBER
Rewards Points: 4,030
A French drain might be better, buried underground, and then a deck over it.
ED
de-nagorg is online now   Reply With Quote
Old 02-24-2018, 08:13 AM   #9
Rewards Points: 2,800
It is better if the primary water flow is away from the foundation.
The more water runs by your foundation, the more water will soak in before getting all the way past, and this will aggravate basement flooding problems and/or increase the load on your basement sump pump.
A disadvantage of an underground French drain compared with a swale is that you need more downgrade to work with to get the water that entered the French drain back out to the surface to run down your existing drainage slope at the edge of your property (top of your diagram) beyond your addition.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 02-24-2018, 09:28 AM   #10
Rewards Points: 207
I don't have a basement. Just very low crawl space.
Old 02-24-2018, 10:02 AM   #11
Big Dog
Drachenfire's Avatar
Rewards Points: 3,994
I had an issues with water at the back of my house flooding my lower floor due to a slight slope of the property.
I installed a french drain system to move water from the back of my house and around to the front.
Looking at from the back it works this way. The property slopes from right to left and back to front.
There are downspouts on both ends of the house.
The drain is connected to the downspout it then moves to the left and goes into a two a grated top 12"x12" catch basin. There is then about 6 feet of drain pipe and another grated top 12"x12" catch basin. These basins are what collect the water flow from the yard. The pipe then continues to the left corner where that down spouts ties into the system. From there it runs diagonally across the yard to the low point where it is connected to a pop-up diverter. The connection to the downspouts serve two purposes it keeps the water from the yard and it helps flush the french drain pipe.
I have had that system in for about 5 years now and it continues to work perfectly.
de-nagorg likes this.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Washing machine drainage issue Centex2011 Plumbing 6 10-08-2014 03:45 PM
get rid of swale? kree Landscaping & Lawn Care 6 04-22-2012 08:15 AM
Ideas for Preventing Swale Erosion? (Photos) JustADoc Building & Construction 4 08-17-2011 06:49 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
