Help With A 1st Floor Under Deck Drainage System - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-03-2014, 01:06 PM   #1
Rewards Points: 16
Question
Help with a 1st floor under deck drainage system
Hello everyone!
First time posting to this forum. I recently started to DIY around my condo and it's really fun and rewarding. After I refinished my deck, my dad loved the result he asked me to help him with his. So when to his house, I saw alot of water pooled underneath a section of the deck, I will post a link to pictures on a reply to this post, since I can't post a link right now.
http://imgur.com/a/eMd7C
Ok so first thing, Alot of the boards are rotted out, so we're just going to replace them all. My main concern is, underneat the deck is just dirt/soil/mud/clay--which is bad because it pools water underneath the deck. That allows for mosquitos to breed and rotting out the posts.
I've researched alot of under the deck drainage systems, but it looks easy to install for 2nd floor decks. For 1st floor decks, what do you all recommend is this easiest way to divert water from under the deck to yard so it wont collect underneath?
jmill155 is offline   Reply With Quote
Old 11-03-2014, 01:11 PM   #2
Rewards Points: 17,912
How close to the ground is this deck?
Old 11-03-2014, 01:18 PM   #3
Rewards Points: 16
I think there's about 12"-18 " clearance
Old 11-03-2014, 01:56 PM   #4
Proper grading and a gutter over that area should do it.
Old 11-03-2014, 02:00 PM   #5
Proper grading, silt screen some #57 stone and a gutter over that area on the roof should do it.
Old 11-03-2014, 02:00 PM   #6
Proper grading, silt screen then some #57 stone and a gutter over that area on the roof should do it.
jmill155 (11-03-2014)
Old 11-03-2014, 08:12 PM   #7
Rewards Points: 38
Water runs down hill.
While you have the deck boards off, put some more dirt under the deck until it is higher than the surrounding yard. The water will now run out into the yard and not pool under the deck anymore.
crf731 is offline   Reply With Quote
The Following User Says Thank You to crf731 For This Useful Post:
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
leaking deck repair notacontractor Building & Construction 0 08-21-2012 11:34 AM
Looking for ideas to adjust drainage for well deck centerisl Building & Construction 2 07-23-2012 10:34 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
in floor heating system and deck mud zantar Flooring 1 07-13-2010 06:50 PM
