Hardie 6 Station Total Control - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-24-2016, 08:35 PM   #16
Rewards Points: 507
Re: Hardie 6 Station Total Control
Originally Posted by djlandkpl View Post
Put the inlet piping back together, prime the pump and see if it starts pulling water. I don't see a relay to control the pump in the panel. Just plug the pump into a 120V receptacle.
Dan,
That's the first thing I did, before cutting the elbow off the pvc inlet. Couldn't pull a lick. My bench test on pump confirms that it pills.
Are you thinking that the PVC is a well pipe? I was hoping it was, but it has an elbow 18" below grade. I've never seen a well with a joint in it's piping before.
LarryJ-nova is offline   Reply With Quote
Old 03-24-2016, 09:53 PM   #17
Rewards Points: 206
First thought it's a well. Could it be a cistern under the driveway? That could explain the bend. Are wells common in your area?
Dan
djlandkpl is offline   Reply With Quote
Compressor not coming on. Painter covered it with dropcloth while it was running! vestaviascott HVAC 11 09-10-2015 01:31 AM
Wiring Fan Control - Where in the chain to place the control? sub780lime Electrical 4 02-03-2015 11:26 AM
Turn thermostat to COOL (mobile home split system), fuse on control board blows. justplumducky HVAC 8 04-29-2013 08:42 PM
Dishwasher Control Panel Zen Nomad Appliances 0 10-02-2010 12:00 PM
Thoughts on wiring new attached garage/hallway Mi Feller Electrical 45 06-18-2010 07:47 PM
