Is It Hard To Rip Out A Mature Yellow Ribbon Arborvitae? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-26-2015, 06:36 PM   #1
Rewards Points: 18
Is it hard to rip out a mature yellow ribbon arborvitae?
First of all, is this a yellow ribbon arborvitae?
Second, are these shrubs hard to pull out of the ground? These things are about 5' x 4' and have a trunk about 4 inches wide at the base. They are completely overgrown and wrong for the space.
I know you can pull on yews with a backhoe and the roots hold firm. I'm curious what I'm in for with these, what I assume are, overgrown yellow arborvitae.
Thanks in advance!
chaz7979 is offline   Reply With Quote
Old 03-27-2015, 07:06 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... Wrap a chain 'round it, 'n pull,...
You'll have yer answer in short order,....
Bondo is online now   Reply With Quote
Old 03-27-2015, 07:55 AM   #3
Rewards Points: 6,997
Looks more like a globe arborvitae to me. I can't find any definitive online verification but I don't recall them being very deeply rooted. A good watering a day or two before pulling or digging and they should not be too much trouble to get out.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 04-11-2015, 04:01 PM   #4
Rewards Points: 535
Yes, it will be difficult to remove every root. Cut off the base of the plant with a chain saw and haul it away. Go back with a trowel, shovel and perhaps a digging bar. Excavate around the trun stub so you can identify where the main roots branch off. Dig down around those several inches to expose them.
Get a reciprocating saw with a long wood cutting blade, and sever those roots. There is likely a main, or tap root descending directly below the stump; get that as well.
The plant will not regrow there if you follow that procedure. However, the remnants of roots may remain for some time until they rot, complicating a replant in that hole if you are putting in anything larger than a five gallon plant, i.e., anything with a root ball.
It's not the same as completely removing all the roots, but a lot less labor.
Curmudgeon10 is online now   Reply With Quote
Mysterious Yellow How Water in Tub only heyjoe91 Plumbing 11 10-22-2013 03:23 PM
Why the yell is yellow so hard? mckaymotoworks Painting 21 08-07-2012 09:10 PM
Why has my white paint work turned yellow S. Alton Painting 6 07-07-2011 11:52 AM
Hard drive redline PC Repairs & Upgrades 14 03-06-2009 04:27 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
