Ground Drainage - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-28-2017, 06:00 PM   #1
Rewards Points: 34
Ground Drainage
I have an area of grass(won't grow) about 20ftX5ft and 15ftX5ft in the shape of an L. I've tried unsuccessfully to grow grass the the area stays to wet and shaded. The dirt is made up of a lot of clay, some rocks, and sand. Ideally I just want to install turf but feel I the ground needs some sort of drainage. Any ideas would be helpful and I can add picture if need be.
Phickman1 is offline   Reply With Quote
Old 04-28-2017, 07:28 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Re: Ground Drainage
Ayuh,.... That will help,....
Ya gotta figure out which way is downhill, 'n which way is uphill to drain yer wet spot,....
Old 04-29-2017, 08:42 AM   #3
Rewards Points: 34
Re: Ground Drainage
Here are some pics...the grade isn't pretty much flat
Ground Drainage-img_0206.jpg   Ground Drainage-img_0209.jpg   Ground Drainage-img_0210.jpg
Proper way to ground box when t=it has lots of ground wires ogandou Electrical 16 12-03-2017 06:41 PM
Combined ground and neutral wanderwind Electrical 17 07-20-2015 06:15 AM
Ground wire from panel to ground rod swbrains Electrical 46 09-03-2014 05:05 AM
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 03:05 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
