Greener Lawn Question. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-24-2016, 05:54 AM   #1
Rewards Points: 76
greener lawn question.
good morning all. i have been a home owner for three years now this is the first year i got a complament on my lawn saying it looks like a carpet. i want to make it greener its nice and full and thick just light in some areas whats a good fertilizer to use i use scotts 4 step program. just wanted to see if there was anything just to use for greener lawn.also another problem is when i use two sprinklers at one there is no pressure to run them bith so any ideas on what i can do to get enough pressure to run them both i dont mind not runnijg togethet its just i have to unplug one tjen con ect it to other.
Sent from my SM-G900V using Tapatalk
charles3526 is offline   Reply With Quote
Old 06-24-2016, 06:22 AM   #2
HDS
Rewards Points: 318
Re: greener lawn question.
May want to take some soil samples to be tested. It'll tell you what nutrients your lawn needs.
HDS is offline   Reply With Quote
Old 06-24-2016, 06:34 AM   #3
Rewards Points: 76
would lime work?
Old 06-24-2016, 07:19 AM   #4
HDS
Rewards Points: 318
That is what the soil testing will tell you.
Old 06-24-2016, 05:59 PM   #5
Rewards Points: 1,042
Nitrogen will green it up fast.
Canarywood1 is offline   Reply With Quote
Old 06-24-2016, 08:50 PM   #6
Rewards Points: 2,579
Cool season grasses go dormant when it gets hot. Lots of water is all you can do.
I don't understand the problem with the sprinklers. Turn one off, turn the other one on. Why do you have to unplug? Maybe you need another hose or a Y-adapter?
I have a simple shutoff valve on the end of my house. I can switch from my power washer to my sweeper nozzle to my sprinkler with a quick quarter turn. I never have to run back to the house and turn that spigot handle 100 times. I recommend it.
http://www.homedepot.com/p/Melnor-Me...395S/203136689
mathmonger is offline   Reply With Quote
Old 06-24-2016, 10:18 PM   #7
Rewards Points: 58
Ok, here is my setup for my front lawn.
I have 2 spike sprinklers on each corner in the front.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I run 2 separate hoses to them and have them on a timer. my water pressure is only good enough for 1 sprinkler at a time so I have them on seperate channels and one runs for its specified time then after about a minute of it being off the other one starts. no interaction needed from you once you set it up. This timer gives you 2 automatic valves and a third manual valve that you can use without having to unhook everything.
Doomsday is offline   Reply With Quote
Old 06-24-2016, 10:46 PM   #8
Rewards Points: 744
Iron will green it up, without speeding up the growth.
Seattle2k is offline   Reply With Quote
Remove old lawn first or concrete first? jimleahman Landscaping & Lawn Care 6 04-26-2012 03:56 AM
Well pump question Davidb6 Plumbing 4 05-04-2009 02:41 PM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 08:38 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 11:36 AM
