Gravel Side Of My House? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-28-2016, 09:29 AM   #1
Rewards Points: 34
Gravel side of my house?
Hi all, i was thinking of removing some dirt from the side of my house and filling it with white gravel? Is it a good thing to do? Hoe many inches deep should i dig? Should i put an underlayment? I am doing this because i cant stand dirt touching the side of my house and Will give it better curb appeal plus it will help with side rott. What so you all think?
weimed is offline   Reply With Quote
Old 02-28-2016, 09:32 AM   #2
Rewards Points: 17,912
Post a picture.
Any siding should be at least 6" above grade.
Old 02-29-2016, 11:47 AM   #3
Rewards Points: 34
Side pf the house
Old 02-29-2016, 01:28 PM   #4
Knows Enough to be Danger
Rewards Points: 1,213
It's hard to say in the picture, but the siding isn't quite flush to the ground, is it? That may change the equation a bit.
But for your original question, a lot of houses have some sort of stone or mulched border around them.
I'd recommend laying down the fabric under the stone. Keeps the stone from sinking, and no weeds poking up through it.
NickTheGreat is offline   Reply With Quote
Old 02-29-2016, 04:21 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,.... Done that on alota commercial buildin's,....
What I did at my place was to dig out 12"/ 18" deep, 2' out from the foundation, pitchin' the dig, Away from the foundation, 'n to the low side of the house,.....
I laid in 2 layers of 2" thick Dow blueboard foam insulation,....
Then filled in the rest with 3/4" minus crushed limestone, pitched Away from the house, 'n to the low side,....
A line of larger limestone serves as a border,....
We've since added large stones from Maine over the area,....
Vinyl sided chimney on side of house - rotting OSB rfleege Roofing/Siding 55 11-23-2010 08:23 AM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
House 2 years, 5 months old now has huge bulge on side of house. Dee Johnson Building & Construction 16 10-09-2010 07:28 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
