Gravel Pathway Erosion - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-24-2018, 10:19 AM   #1
Rewards Points: 56
Hi All,
I have a sloped backyard with a gravel pathway which has slowly been eroding after each rain storm. I have a gutter end-spout that is on the elevated portion of the pathway...thus, the main reason why water naturally travels down the pathway.
What are my options to limit or even eliminate this issue in the future?
1) Would a catch basin be effective?
2) Attach an even longer gutter downspout that carries ALL the water down and away from the path?
3) Or should I completely rebuild this and install a Honeycomb Pathway Stabilizer Grid (with a heavy-duty landscape fabric barrier as the base)? https://www.amazon.com/Core-Path-Sta.../dp/B013KOTO40
Any help is appreciated! Thanks!
Gravel Pathway Erosion-yard1.jpg   Gravel Pathway Erosion-yard2.jpg   Gravel Pathway Erosion-yard3.jpg
stacik84 is offline   Reply With Quote
Old 09-24-2018, 10:23 AM   #2
retired framer
Rewards Points: 20,660
Re: Gravel Pathway Erosion
Does the yard drop off on the other side of the path or is the neighbours yard?
Old 09-24-2018, 10:28 AM   #3
Rewards Points: 56
Still my yard...drops off to the base near the shed.
Old 09-24-2018, 10:31 AM   #4
retired framer
I would run the downspout thru the deck to a pipe running under the deck and then go under the path to a day light opening on the other side.
Old 09-24-2018, 12:46 PM   #5
retired painter
Rewards Points: 1,852
Ya, the more water you can keep off the walkway the better! Moving the downspout should be a priority.
mark sr is online now   Reply With Quote
Gravel Pathway Erosion stacik84 Concrete, Stone & Masonry 1 09-24-2018 01:01 PM
Gravel Driveway Erosion Problem Mills314 Landscaping & Lawn Care 12 10-07-2013 09:31 PM
Gravel Parking Pad into Concrete Driveway Contractor Question janina5309 Concrete, Stone & Masonry 3 07-27-2013 02:54 PM
Gravel Driveway Erosion dcm3030 Landscaping & Lawn Care 12 09-19-2012 10:17 AM
Dirt erosion underneath concrete front steps, fill with gravel? NewHomeDIYGuy Building & Construction 2 07-10-2012 01:44 PM
