Grass Killing Black Lab Urine - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree29Likes
Old 04-01-2017, 08:36 PM   #1
Hvac contractor
Rewards Points: 578
Grass killing Black Lab urine
thats right, I have a black Lab, his name is Einstein and wherever he pees, the grass dies? I now have a back yard with little spots of dead grass all over the place.
So my question is, how do I get the grass to grow back.???
Is there a special fertilizer?
donste2010 likes this.
jeff00 is offline   Reply With Quote
Old 04-01-2017, 09:40 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Grass killing Black Lab urine
Water. Lots and lots of water. Water the p1ss out of it, so to speak.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-01-2017, 10:19 PM   #3
Hvac contractor
Rewards Points: 578
LOL ok, although after yesterdays 1.25", Im going to hold off for a day or two
Old 04-01-2017, 10:42 PM   #4
jlhaslip's Avatar
Rewards Points: 708
Actually, aerate the lawn, spread a layer of sand and nitrogen fertilizer should do the trick.
Old 04-02-2017, 07:25 AM   #5
Hvac contractor
Rewards Points: 578
what fertilizer has nitrogen ~~~ Honestly, I can take any furnace or a/c apart and put it back together inside a hour. I don't know about lawns and fertilizers. I got at least 5 varieties of weeds in my lawn.
Should I aerate/fertilize/seed the dead spots. My guess is, I need to treat the entire lawn. but I don't know how or when? and I can't afford a lawn care bizz.
I have to admit, Einstein is pretty good at peeing in a 20x20 foot area.
I had two Lab's before this guy and neither one killed grass like this one?
Old 04-02-2017, 01:21 PM   #6
jlhaslip's Avatar
Rewards Points: 708
The first number is the amount of nitrogen (N), the second number is the amount of phosphate (P2O5) and the third number is the amount of potash (K2O). These three numbers represent the primary nutrients (nitrogen(N) - phosphorus(P) - potassium(K)). This label, known as the fertilizer grade, is a national standard.
A brief description of each major nutrient will show why grass has its own preference for fertilizer.
Nitrogen:
essential for growth of foliage;
produces lush, tender, green leaves (or grass blades);
deficiency results in a yellow-green color (chlorosis) and little or no growth;
is easily flushed through the soil.
Phosphorous:
stimulates root growth;
hastens the maturity of plants;
promotes development of flowers, fruits, seeds;
deficiency can result in slow or stunted growth and purplish discoloration on leaves;
remains in the soil quite well.
Potassium:
gives vigor to tolerate changing weather conditions;
helps resist disease;
assists in the food manufacturing process;
strengthens cell wall structure for strong stems;
deficiency can cause week stems and slow growth;
leaches from the soil, not so fast as nitrogen.
Couple of tidbits off the Interwebs to help you out.
I think you might be happy with a 21-3-3 or something that is a big-small-small number set.
donste2010 and jeff00 like this.
The Following User Says Thank You to jlhaslip For This Useful Post:
jeff00 (04-02-2017)
Old 04-02-2017, 01:36 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,.... My 1st thought for a Cure is to shoot the dog,....
2nd option is what All my neighbors have done,....
Teach yer dog to piss in the neighbor's yard,....
Gymschu likes this.
Old 04-02-2017, 03:11 PM   #8
Hvac contractor
Rewards Points: 578
I'd rather have dirt and rock for a lawn.
that's just rude
The Following User Says Thank You to jeff00 For This Useful Post:
MTN REMODEL LLC (04-03-2017)
Old 04-02-2017, 05:56 PM   #9
Bondo's Avatar
that's just rude
Ayuh,.... I wish my neighbors agreed,......
jeff00 likes this.
Old 04-02-2017, 06:08 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,650
Jeff...Bondo is pulling your leg buddy.
He would shoot a liberal if they peed on his yard...but not a dog.
Old 04-02-2017, 06:09 PM   #11
Hvac contractor
Rewards Points: 578
then we're all on the same team....
Bondo and MTN REMODEL LLC like this.
Old 04-03-2017, 11:31 AM   #12
Rewards Points: 266
Here's a tip moving forward - as soon as the dog pees, throughly water that spot. I keep a full watering can outside (you can also use your hose). The water will dilute the pee and prevent it from killing the grass in the first place. So far it's worked for me (at least it's drastically minimized pee spots).
Marky82 is offline   Reply With Quote
The Following User Says Thank You to Marky82 For This Useful Post:
jeff00 (04-03-2017)
Old 04-03-2017, 02:35 PM   #13
Have you looked at those grass saver dietary enzymes? I thought this was confined to the female dogs, but maybe not.
I wouldn't feed my pooch anything unless I was sure of what it was and does, but there are some dietary options out there.
Old 04-03-2017, 02:38 PM   #14
Rewards Points: 4,366
Is it unrealistic to teach a dog where to pee?
Nik333 is online now   Reply With Quote
Old 04-03-2017, 03:04 PM   #15
Bondo's Avatar
Ayuh,.... I think it's fairly common to house train pets,....
Same thing,...
Obviously works,.....
Every critter on my dead-end street does their business in My yard,....
Nik333 likes this.
help bermuda grow into patchy spots denemante Landscaping & Lawn Care 5 05-28-2014 10:06 AM
Tankless - Black Soot Problem BillGrayslake General DIY Discussions 0 04-13-2013 01:02 PM
Synthetic grass, anyone have experience w/ it? NewHomeDIYGuy Landscaping & Lawn Care 8 03-05-2013 03:35 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
