Grading Issue - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-10-2018, 05:19 PM   #1
Rewards Points: 18
Grading issue
From old finished grade 20 feet away to fence of old finished grade I am level.
Putting proper grade would look rediculous with current fence. Also there is a 3 foot common piece of grass before curb and street behind fence so grading would create a trench . Not sure what to do here
Dirtmcgurt is offline   Reply With Quote
Old 07-10-2018, 05:40 PM   #2
Rewards Points: 6,094
Re: Grading issue
Pictures would help and your approximate location. Snow, frost, and how close other properties are important. If you have any idea as to the soil and drainage around your house let us know, clay or sand?
Bud
Bud9051 is offline   Reply With Quote
Old 07-10-2018, 05:59 PM   #3
Rewards Points: 18
Re: Grading issue
I'm in southwest Montana . It can get below zero. Pretty dry here all considered. I don't know what kind of mix for dirt. Looks maybe a little clay in rocks about 6 to 8 inches down.it is a 4 plex
Old 07-10-2018, 06:44 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Re: Grading issue
Ayuh,..... The water has to go Somewhere,.....
Pick a point, drive a pin, 'n make everywhere else, Higher, by an inch every 10',......
Any water will drain to that point,....
Any water comin' in from elsewhere,..??
Old 07-10-2018, 06:50 PM   #5
Rewards Points: 18
Re: Grading issue
I can pull an inch every ten feet without it lookin too goofy. The neighbor to the right has river rock on top of felt so if I imagine a little could flow towards me if I drop some but if I can squeeze an inch or two I guess it could work. Can't get worse then negative grade I guess
Old 07-10-2018, 11:45 PM   #6
Re: Grading issue
A lot depends upon how much water you get, but a collection point and a pit filled with stones to encourage the water to go down might take care of some. What is outside the fence, any low areas where the water could be directed?
Bud
Old 07-10-2018, 11:57 PM   #7
Rewards Points: 18
Re: Grading issue
A 3 foot patch of grass around the 4 plex then curb then street. The power box and cable pedestal are right behind the fence too. It's been this way since it was built 9 years ago so we don't get too much water apparently , crawl isn't flooding . I can take a picture behind the fence tomorrow. Looked like junk since I moved in . Voles and huge rocks under sod. Dead mossy spots . Just now tackling it.
Old 07-11-2018, 12:15 AM   #8
Re: Grading issue
SW Montana, been awhile. Grandparents used to live in Sula, then Corvallis, then up near Missoula. I do remember their strawberry patch .
If the soil is deep you could set a drainage pit (concrete ring) with a metal cover. Did one of those in NJ and it has worked for almost 40 years, but they have pure sand.
Enjoy,
Bud
Old 07-11-2018, 12:27 AM   #9
Rewards Points: 18
Re: Grading issue
I'm sure it's changed a lot since you were here last. Good and bad.
I think I can squeeze a few inches of grade in and get this done. If I need to later I will carve a few feet off the fence line and grade into a pit as you suggested. Doubt I will need to it's pretty dry up here even with the snow. It's a 4 plex so I will just have to deal with it.☺️
Thankyou
Comfortmaker Furnace Firing Issue Drillz HVAC 6 12-26-2017 03:59 PM
Grading Issue: Looking or help Karnite Landscaping & Lawn Care 3 05-07-2017 05:05 PM
HVAC condensor fan outside intermittant wheelsup HVAC 21 05-24-2012 10:25 AM
Negative Grading and Soil to Wood Siding Contact Fix? connor016 Building & Construction 14 01-22-2012 10:44 AM
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 05:50 PM
