Good AUTOMATIC Weed Killer Sprayer? Long Handle? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-08-2016, 08:11 PM   #1
Rewards Points: 117
Good AUTOMATIC weed killer sprayer? Long Handle?
Hey guys - finally figured that I would round up around my new chain link fence this summer.
I am 6 feet tall, and do not want to be hunched over going around a couple hundred feet of perimeter. Nor would I like to stop every 10 feet to pump something if avoidable.
And, of course, I don't want to spend a lot!
Can anyone recommend an automatic sprayer that they have used that has a LONG handle or telescoping handle - and is battery powered - yet has a good strong spray?
Thanks for any suggestions!
PS - I don't reeeaally care about how many gallons it holds if it meets the above specs.
LordX is offline   Reply With Quote
Old 04-11-2016, 07:08 AM   #2
Rewards Points: 297
Re: Good AUTOMATIC weed killer sprayer? Long Handle?
You should care about the capacity. If you've got enough fence line to make your back hurt while doing it . . . you've got enough fence line to where it's going to get annoying stopping to mix another gallon over and over. Most of the decent quality battery sprayers (Chapin, Solo) are going to run you well into the $100 range. You'd be better off with a manual backpack style.
red92s is offline   Reply With Quote
Old 04-12-2016, 07:51 PM   #3
Rewards Points: 1,042
$22.00 when you use the 20%off coupon,pretty good deal.
http://www.harborfreight.com/4-gal-b...yer-61368.html
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
LordX (04-20-2016)
Old 04-12-2016, 09:52 PM   #4
Rewards Points: 30
I think you're underestimating the pump sprayers. My 2 gallon roundup brand works great, has a huge spray pattern and will last quite a while before needing to repump. I filled it up with 1.5 gallons last week and I had stop 4 maybe 5 times to repump.
Premium08 is offline   Reply With Quote
Old 04-20-2016, 10:16 AM   #5
Rewards Points: 117
Bought the harbor freight one (so cheap - worth a shot).
It sprays GREAT.. I have to keep pumping to keep up the pressure, but its a backpack - so I dont have to stop spraying while I pump. I must look hilarious, but it works!
Now my gripe is the round-up concentrate I bought.
I got the regular concentrate - poured the WHOLE thing into 4 gallons.
So like 1.4 times what it needs. Figured this would annihilate the weeds/grass that I didn't want... no such luck. 2 days later now, and maybe a LITTLE sign of browning in SOME areas...
Maybe I will get the SUPER concentrate (50% active chems).
Old 04-20-2016, 10:40 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,..... Round-up takes alittle time, give it a week,.....
If ya want instantaneous results, spray a high concentration of Clorox bleach,...
The bargain brands right outa the bottle are a close 2nd,....
Old 04-20-2016, 08:06 PM   #7
Rewards Points: 117
Interesting... never thought about bleach. How long do the results last though?
Old 04-21-2016, 06:31 AM   #8
Bondo's Avatar
Ayuh,... It'll kill what's there when ya spray,....
It dissipates quickly,.....
When new seeds fall/ blow in, of course they can grow,....
Good Air Gun Sprayer for DIY'er exterior home painting Skelleyman Painting 2 12-07-2012 05:28 PM
Minwax Polycrilic - How long is it good for? CubsWin Painting 4 10-11-2012 01:22 PM
Recommendation on a good furniture grade sprayer + other questions..? noone Painting 0 02-13-2012 08:49 AM
Milwaukee Airless/ Fine Finish Paint Sprayer (good or bad?) ehoez Painting 3 10-09-2010 01:56 AM
Bayer liquid weed killer & 2 Gallon flomaster pressure sprayer combo pack @ HD $10 whataboutj Landscaping & Lawn Care 25 05-13-2010 10:01 PM
