Front Covered Porch-nothing Underneath - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-29-2015, 10:49 AM   #1
Rewards Points: 115
Front covered porch-nothing underneath
We're building a house via the modular route, and I'm building the front covered porch myself among a few other items.
The deck of the porch will be about 2-3 feet off the ground and we want to make sure nothing grows from underneath the porch. What is the best way to ensure that nothing will ever grow and be a pain to get rid of in the future since we'd have to crawl underneath the porch.
We were thinking weed barrier underlayment and then an inch or two of gravel over it.
Thanks for any help you can provide!
6fthook is offline   Reply With Quote
Old 03-29-2015, 12:12 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,.... If the Sun don't shine on it, nothin' will grow,.....
If it's good, 'n Dry, things won't grow,....
Yer plan will work if the Sun don't shine on it, 'n it don't get wet,....
Otherwise, the fabric, 'n stone will just slow the process,....
Old 03-29-2015, 12:19 PM   #3
Rewards Points: 17,912
Hitting the area with total vegatation killer before covering it will slow things down.
At some point no matter what you do stuffs going to try and grow.
The weeds will grow right through and on top of weed block. The weed block will just make it a whole lot harder to pull it out by the roots.
Old 03-29-2015, 12:51 PM   #4
Property Mgt/Maint
Rewards Points: 6,522
cover with a seamless sheet of 6 mil black poly, then add on 2 to 3 inches of crushed stone.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 04-10-2015, 10:32 PM   #5
TruproServices.com
TruproServices's Avatar
Rewards Points: 80
As previously mentioned, it's unlikely that anything will grow below it anyway. If it has a foundation a vapor barrier wouldn't hurt to prevent moisture issues and it would prevent any weed growth as well.
TruproServices is offline   Reply With Quote
Front Covered Porch Post and Column wewantutopia Building & Construction 10 06-26-2014 09:20 PM
front brick porch genuin Building & Construction 9 01-09-2012 03:04 PM
Pre-planning: converting front room back to porch WillK Building & Construction 3 11-06-2011 12:47 PM
Front porch shed roof addition GIDGEEGIRL1 Building & Construction 0 10-28-2010 12:16 AM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 09:16 PM
