French Drain On A Slope To Slow Down Water Flow - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By lenaitch
Old 04-13-2018, 05:39 PM   #1
Rewards Points: 6
French drain on a slope to slow down water flow
Hello everyone,
Ive just been notified by the township zoning department that the water flowing off our property is eroding our neighbors gravel drive and washing it out onto the road. Weve recently had some major rains in southwestern Ohio and I must admit when I saw logs float past my living room I decided to consider reworking the ditch to slow down the water. Now after speaking to the neighbor and the zoning inspector I think it may be best to install a French drain to absorb and slow down the flow. A plus would be that I may actually make the yard easier to mow.
Im getting a excavator out here in a few weeks to finish up a tiered garden but I might as well trench the drain then too. What type of stone should I be looking for. Where would you look to get reduced prices. When I got gravel for my driveway I contacted a paving contractor and had 11tons of road bed dropped for $120, and $20 for delivery.
Chuck08 is offline   Reply With Quote
Old 04-13-2018, 05:55 PM   #2
Rewards Points: 6
Re: French drain on a slope to slow down water flow
Old 04-13-2018, 05:57 PM   #3
Guapo
Rewards Points: 11,950
How much higher is your property than his? Is there a retaining wall? How long is his driveway? Can you post some wide angled pics?
Guap0_ is offline   Reply With Quote
Old 04-13-2018, 05:57 PM   #4
Rewards Points: 6
As you can see in the pictures the yard has a good slip to it and the water just gets moving.
Old 04-13-2018, 05:59 PM   #5
Guapo
I guess that our posts crossed. What does that pic show us? I don't see the driveway.
Old 04-15-2018, 10:14 AM   #6
Rewards Points: 4,796
Is this natural and undisturbed ground.?
If it is, it might not be your problem to solve.?
ron45 is offline   Reply With Quote
Old 04-15-2018, 12:31 PM   #7
Usually Confused
lenaitch's Avatar
Rewards Points: 240
I suppose a trench filled with stone is by broad definition a 'french drain'. One thing to keep in mind is that if the flow of water is slowed, it will either pond on your property and then absorb into the ground or absorb into ground around the trench. You have to determine if that level of saturation will cause other problems, particularly in relation to your foundation or that retaining wall. Is there another area to direct it to via a drainage tile?
Bondo likes this.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 04-15-2018, 05:05 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,786
Ayuh,..... 4" to 6" stone, No fines, just biggish rocks,.....
From a Quarry is the Best place to look,..... yer gonna be needin' quite a few tons,....
Bondo is online now   Reply With Quote
Old 04-15-2018, 07:14 PM   #9
Rewards Points: 1,042
If you want to slow the velocity of the water, you will need a graded size of riprap as opposed to a uniform size, 4" to 5" would be the size to attain that and it would be best if it was on top of filter fabric to avoid scouring.
Canarywood1 is offline   Reply With Quote
Old 04-19-2018, 03:09 PM   #10
Rewards Points: 2,800
Does some of the water come from other neighbors' properties uphill? Did the township zoning department discuss it with them also?
How many times during the year does this problem occur?
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 04-22-2018, 12:33 AM   #11
Rewards Points: 34
So it's all on you? Water flows downhill. Has your neighbor done anything to address it?
AnotherHomeOwnr is offline   Reply With Quote
Old 04-23-2018, 10:15 AM   #12
Rewards Points: 6
In the first picture, the ditch curves from behind the woodpile before the water comes back out. and down the orange line in the grass. There is a spot where water rains into something and then a 15ft area of a dry ditch before water comes back up, i believe this to be a rock-filled pit put in by the farmer to slow the water off his property. This ditch was created by a previous owner when the retaining wall and living room were added on. The length of the portion pictured is approximately 200ft and drops 10 ft.
in the second picture, you can see the back of my neighbors home, the flow of the water crosses back and forth on the property line before going into the culvert to cross under the road. the drop from where I took the picture to the road is approximate, 18 ft and is 200 ft long.
One of the issues is that the speed created in the first picture doesn't allow the water to turn into the channel along the property line. washing through the woods, over his retaining wall, and into his driveway.
My issue is that the ditch is difficult to mow and logs and debris get strewn across my backyard. I also had a waterfall over the retaining wall shown in picture 1 that washed out the courtyard garden below.
now all that being said, this only happened twice to us, this spring, when we had two storms come through that dumped 2" of rain in 2 hours then rained for a day or so on top of that. Cincinnati's riverfront and towns along the Ohio River flooded during these storms, so our issues is a relative small one.
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 10:27 PM
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 08:14 PM
Proper Slope for Sump/Gutter Drain dankoos Plumbing 0 05-06-2013 01:59 PM
French Drain or some other idea for wet yard wnewman Landscaping & Lawn Care 10 07-26-2012 09:33 AM
french drain slope HHac8014 Landscaping & Lawn Care 1 08-10-2011 09:36 PM
