French Drain Slope - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 08:52 PM   #1
french drain slope
Hi all, I'm putting in a french drain this weekend and wondered what this board thought of the required slope.
HHac8014 is offline   Reply With Quote
Old 08-10-2011, 09:36 PM   #2
Rewards Points: 2,864
Where is the French drain located.
If it is underground right against the foundation footings you probably can't have more than two inches of vertical drop in total. You may not excavate below an imaginary surface starting at the bottom side edge of the foundation footing and extending away and slightly down at a 1:3 slope. If you set the drain pipe 1 foot away from the footing you can dig the trench no more than 4 inches below footing bottom level and gain a few more inches of vertical drop. The pipe at the high end has to be a few inches below the basement floor. And you need some gravel under the pipe.
Retaining Wall / French Drain Question bsmith95610 Landscaping & Lawn Care 8 05-18-2012 10:48 AM
Installing french drain / weeping tile Troglodyte Landscaping & Lawn Care 0 05-12-2011 09:33 PM
Interior French Drain Cement Necessary bern8277 Building & Construction 5 10-31-2010 04:16 PM
french drain waterproofing basement windy1 Building & Construction 6 10-21-2010 06:33 AM
French drain question Tom Fan Landscaping & Lawn Care 3 06-04-2007 07:16 PM
