DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Landscaping & Lawn Care (https://www.diychatroom.com/f16/)
-   -   french drain slope (https://www.diychatroom.com/f16/french-drain-slope-113632/)
HHac8014 08-10-2011 07:52 PM
french drain slope
Hi all, I'm putting in a french drain this weekend and wondered what this board thought of the required slope.
AllanJ 08-10-2011 08:36 PM
Where is the French drain located.
If it is underground right against the foundation footings you probably can't have more than two inches of vertical drop in total. You may not excavate below an imaginary surface starting at the bottom side edge of the foundation footing and extending away and slightly down at a 1:3 slope. If you set the drain pipe 1 foot away from the footing you can dig the trench no more than 4 inches below footing bottom level and gain a few more inches of vertical drop. The pipe at the high end has to be a few inches below the basement floor. And you need some gravel under the pipe.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
