French Drain - Dirty Gravel? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-16-2014, 08:31 PM   #1
Rewards Points: 16
I'm building a french drain in the backyard and so I ordered some 3/4" gravel from a local supplier. They delivered it, however the gravel came with some 3/4" pieces but a lot of it is much smaller and there is a lot of sand/dirt in it. Is this typical when ordering 3/4" gravel? Can I use it in the French drain or do I need something where all the pieces are the 3/4" size?
alfer is offline   Reply With Quote
Old 12-17-2014, 06:41 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,.... Sounds like ya ordered, or atleast got 3/4", Minus,.....
For fillin' 'round a drainage pipe, ya oughta start with 3/4" washed stone, then go to the 3/4" minus as ya near the top of the fill,....
Retaining Wall / French Drain Question bsmith95610 Landscaping & Lawn Care 8 05-18-2012 09:48 AM
Sub-surface water; french drain bergerdude Landscaping & Lawn Care 4 04-04-2012 03:13 PM
57 or 89 gravel for french drain? HHac8014 Landscaping & Lawn Care 1 08-16-2011 04:01 PM
dig trench to install internal french drain is ok on a no footing basement? diy001 Building & Construction 0 01-14-2011 03:10 PM
French Drain Suggestions doublejz Landscaping & Lawn Care 10 04-29-2010 03:19 PM
